help hit a curb and slid back tire along curb..now wheel faces in a bit at the back?
i tired losening the bolt to slide the arm back out a bit but it wont come lose and ideas on wat i need... its ona 93 hatch back no abs thanks
how hard did you hit the curb? do you mean that you slid bolt on the fork?..did you have a camber kit or a skunk2, etc style fork?... need more info..if it is all stock and its bent that way, it could be a bent tie rod, bent knuckle or you frame it self might be bent...it already happened to me before...later man... good luck
yea dude i slid that screw i belive ....my tire is facing in becasue i slid along th ecurb and its th eback righ t...but that screw is so tight any ideas i think i ahve to get to bushines from honda or tha thole lilttle peice..?
then, if you really cant tell from your point of view, your gonna just have to get it checked by someone. fixing the problem, whatever it is is not gonna be easy if you dont already really know what is it...
Delano5050
Suspension & Brakes
Aug 3, 2007 09:29 AM
badnan
May 29, 2002 12:21 PM
