OEM HID to aftermarket HID?
To make a long story short, I got a 95 Integra GSR with a JDM ITR HID conversion.
The OEM HIDs don't clear on either side of the car (driver side: ac line / passenger side: abs module) I don't want to bend lines or remove stuff to make it work. I also don't want to rig the factory HIDs either.
I plan on buying an aftermarket HID kit and use this instead.
My questions are:
What kit will fit on the factory HID headlights?
Will I be able to make this work?
Would I be able to sell the OEM HID and for how much?
Please guys I need help and I've tried searching.
My questions are:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Who Said »</TD></TR><TR><TD CLASS="quote">what kit will fit on the factory hid headlights?</TD></TR></TABLE>
Any kit the includes standard D2S capsules.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Who Said »</TD></TR><TR><TD CLASS="quote">will i be able to make this work?</TD></TR></TABLE>
I see no reason why not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Who Said »</TD></TR><TR><TD CLASS="quote">also would i be able to sell the oem hid and for how much?</TD></TR></TABLE>
Probably, but I'm not sure you'll get a whole lot for just the capsules and ballasts. Probably enough to more or less break even on the replacement ones though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Who Said »</TD></TR><TR><TD CLASS="quote">i got a 95 integra gsr with the jdm itr hid conversion. the oem hids dont clear on either side of the car(driver side the ac line is in the way and passanger side the abs module is in the way) i dont want to bend lines or remove stuff to make it work</TD></TR></TABLE> Just use what you have. The a/c line gets bent slightly and that's it. You won't regret using the oem hid's. IMO they look better than any aftermarket hid I've seen. I had a phillips kit before and it was nice, but the oem hids blow the th phillips out of the water. It's your call, any aftermarket HID out there wil work as a replacement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NWP4LIFE »</TD></TR><TR><TD CLASS="quote"> Just use what you have. The a/c line gets bent slightly and that's it. You won't regret using the oem hid's. IMO they look better than any aftermarket hid I've seen. I had a phillips kit before and it was nice, but the oem hids blow the th phillips out of the water. It's your call, any aftermarket HID out there wil work as a replacement.</TD></TR></TABLE>
what about the passanger side how could i rig this side...i dont wand to cut and extent wires(i dont think it would be safe)anybody ever seen a factory hid kit installed on a older style integra?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Probably, but I'm not sure you'll get a whole lot for just the capsules and ballasts. Probably enough to more or less break even on the replacement ones though. </TD></TR></TABLE>
thanks for the help
thanks for the help
what about the passanger side how could i rig this side...anybody ever seen a factory hid kit installed on a older style integra?
thanks for the help
yes I have seen it, a friend had a 94 gsr with factory HID's, that's why I'm telling you it will fit.
thanks for the help
</TD></TR></TABLE>yes I have seen it, a friend had a 94 gsr with factory HID's, that's why I'm telling you it will fit.
I have brightstar HID kit on my jdm headlight and it doesn't comapre to the stock HID my buddy has! remember! it's not how bright the bulbs are, it's the projection of light... OEM HID housing is made to project the beam a lot better than non-HID housing with HID kit! If I had the choice, I say try to fit the OEM HID!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8-R »</TD></TR><TR><TD CLASS="quote">I have brightstar HID kit on my jdm headlight and it doesn't comapre to the stock HID my buddy has! remember! it's not how bright the bulbs are, it's the projection of light... OEM HID housing is made to project the beam a lot better than non-HID housing with HID kit! If I had the choice, I say try to fit the OEM HID!</TD></TR></TABLE>
what you said is right, but he's talking about using aftermarket HID's with the OEM HID housing. He wouldn't have the problem of having the projection of light fragmented by the non-hid housing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Who Said »</TD></TR><TR><TD CLASS="quote">whats a good kit?
where can i get one cheap</TD></TR></TABLE>I told you opinion man, there is no better kit IMO than the OEM HID's, so I can't really recommend anything. I had a phillips and wan't too happy, so maybe stay away from that. Check out McCulloch's (sp?).
Langsta
19
Jun 22, 2016 08:52 PM
gdrum
Jan 31, 2006 08:22 PM
