best d series r/s ratio for boost? why is vx best r/s ratio?
Old May 7, 2004 | 04:42 PM
boostedcivichatchbacksi's Avatar
Default best d series r/s ratio for boost? why is vx best r/s ratio?
why is teh vx a "best" r/s ratio, im boosting the motor
Old May 8, 2004 | 09:32 AM
Default Re: best d series r/s ratio for boost? why is vx best r/s ratio? (boostedcivichatchbacksi)
bump need help here
Old May 8, 2004 | 09:39 AM
Ricey McRicerton's Avatar
The VX is not a good motor for boost. Period. It has weak rods, a weak block, and pretty much a weak everything else. Also, the transmission is horrid. Get a z6 or a y8 if you're wanting to boost the D.
Old May 8, 2004 | 10:12 AM
743power's Avatar
Default Re: best d series r/s ratio for boost? why is vx best r/s ratio? (Ricey McRicerton)
Don't worry so much about r/s. It's not easily changed on the d-motors like the dohc. If you wanted to swap cranks, you would have to modify the bearing journals and thats expensive.
z6/y8 has the same stroke as an integra LS which may not be "ideal," but it works for a nice torque curve.
96hatchie
Oct 17, 2009 10:58 AM
shakezilla
37
Oct 16, 2009 04:12 PM
E JAY 1
10
Mar 13, 2008 09:02 AM
djsire
Sep 29, 2005 06:30 AM
91hatchcivic
Aug 5, 2003 04:21 AM
