CEL 3, 5 map, 93 ls tb on 01 ls imtake manifold. searched
Old May 7, 2004 | 03:02 PM
Ski11z's Avatar
Default CEL 3, 5 map, 93 ls tb on 01 ls imtake manifold. searched
Searched the topic, but couldn't find anything with the problem I am getting.
Getting CEL 3, 5, 1 or 10? 3 quick flashing 5 holding flashing, 1 holding flashing
map, o2? or idle air control?
01 ls, 93 ls throttle body, using 3 pin map. My tb doesen't have the hole up top for the map, but I just used a 00 gsr denso map sensor and connected a vacume hose to it and connected it to the tb.
Car starts at 2-3k rpm, lowers down to 2k bogs out to 1k and goes up to 2k.
Any suggestions ht?
Old May 7, 2004 | 06:19 PM
Ski11z's Avatar
Default Re: CEL 3, 5 map, 93 ls tb on 01 ls imtake manifold. searched (Ski11z)
anyone ?
Old May 7, 2004 | 06:26 PM
hondaeg8's Avatar
maybe a bad map sensor?
my friend did that with his ls motor and his car isn't doing that.
what happened to the rest of the gsr TB? i could use one
Old May 7, 2004 | 06:27 PM
chad's Avatar
Moderator
the ECU CODES ARE AT THE TOP OF THE PAGE>....how did you search?
Old May 7, 2004 | 06:28 PM
chad's Avatar
Moderator
you probably have map plug and tps plug mixxed up?
Old May 7, 2004 | 06:29 PM
Ski11z's Avatar
Default Re: CEL 3, 5 map, 93 ls tb on 01 ls imtake manifold. searched (hondaeg8)
I just picked up a gsr tb, installed it with a new map and tried using that tb instead, but I'm still getting the same crap high idle, bogging and jumping from rev's.. I think It could be my Idle air control.. anyone know?
Old May 7, 2004 | 06:32 PM
Ski11z's Avatar
When I cover the 2 holes that that are located in the throttle body, completely cover one and cover the other hole that is next to it about 3/4 I can bring the idle down and keep it steady, but once I leg go same ****.
Old May 7, 2004 | 06:37 PM
Ej1_coupe's Avatar
are there supposed to be bolts where you are keeping your fingers to make the idle go down?
dc101
Jun 1, 2011 06:21 PM
92lxsleeper
Jul 29, 2009 09:25 PM
SiR HatchAlot
Jan 18, 2004 05:39 PM
migs
Nov 19, 2003 03:36 PM
B18C-RnVA
Aug 18, 2002 03:01 PM
