bolt on GSR Rear LCA interchangeable with Type R?
Old May 7, 2004 | 02:59 PM
DC2*Integra's Avatar
Default bolt on GSR Rear LCA interchangeable with Type R?
i am swapping my Rear LCA (GSR) with Type R ones, and i would like to know if i can reuse my bolts. thanks!
Old May 7, 2004 | 03:53 PM
_BEN_'s Avatar
Default Re: bolt on GSR Rear LCA interchangeable with Type R? (DC2*Integra)
The bolt that goes through the bottom of the shock is shorter for the type r lca's. But it still may work. just letting you know that they are different sizes.
Modified by _BEN_ at 3:31 PM 5/8/2004
Old May 7, 2004 | 04:35 PM
Default Re: bolt on GSR Rear LCA interchangeable with Type R? (_BEN_)
cool. thanks for the info. im going to try reusing the bolt
Old May 7, 2004 | 04:46 PM
bruinteg's Avatar
New User
Since there is a good chance you can break the LCA bolts which is very common on used Tegs go ahead and get the ITR bolts - they are definitely longer so I don't think the GSR ones are going to fully thread through.
Old May 7, 2004 | 06:27 PM
Default Re: bolt on GSR Rear LCA interchangeable with Type R? (bruinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruinteg &raquo;</TD></TR><TR><TD CLASS="quote">Since there is a good chance you can break the LCA bolts which is very common on used Tegs go ahead and get the ITR bolts - they are definitely longer so I don't think the GSR ones are going to fully thread through.</TD></TR></TABLE>
are u talking about the bolt that goes to the shock or the subframe? or both?
Old May 7, 2004 | 06:37 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2*Integra &raquo;</TD></TR><TR><TD CLASS="quote"> are u talking about the bolt that goes to the shock or the subframe? or both?</TD></TR></TABLE>
The ones that hold the shock in usually seize.
Its probably a good idea just to replace them anyways... use antiseize when re-assembling.
Old May 7, 2004 | 06:51 PM
db8-R's Avatar
I had to change my rear LCA to type R's when I bought my tein flex coilovers! It fits perfect! but you have to chane the rear struts to type R because LS/GSR struts are fork types... type R are different!
Old May 7, 2004 | 06:55 PM
Default Re: (db8-R)
cool. thanks for the replies!
Old May 9, 2004 | 09:28 PM
Default Re: (DC2*Integra)
just did my install yesterday and everything fit in pretty well with GSR bolts. i also took ur advice and used antisieze on it. thanks!
HotCheetos
10
Dec 11, 2010 09:07 PM
ZipTieGUy
Feb 27, 2006 06:08 PM
S2KILLA
Oct 6, 2005 07:59 AM
DC4_MADMAN
Suspension & Brakes
Sep 7, 2005 09:22 AM
Matgallis
Aug 25, 2004 02:36 PM
