erratic idle on ls swap?
Old Nov 4, 2001 | 07:09 PM
crux131's Avatar
Default erratic idle on ls swap?
I just had a b18a swapped into my crx and everything went fine, but as of the past few days, the car has an erratic idle upon startup.
It starts off at a high idle, revs up as high as 3000rpm at times, then decreases. The idle fluctuates up and down, the motor revs up to around 3k, then drops to about 800, then revs again.
The high point drops as he car warms, it starts reving to around 1800rpm's.
This thing runs fine, but it didn't do this when I got it back from the mechanic, it just started, so my question is, whats causing this....a loose vacum line?, a bad sensor?, just a bad connection somewhere?
If this helps, I have a CRX si ecu( for now, I am going to change to a teg ecu ), this is in my dx.
Thanks in advance.
[Modified by crux131, 7:46 AM 11/5/2001]
Old Nov 4, 2001 | 07:19 PM
D-Man's Avatar
Default Re: erratic idle on ls swap? (crux131)
my friends car was doing the exact same thing,,his problem was that a vacuum line was broken going to intake manifold
Old Nov 5, 2001 | 12:15 AM
HyperREV's Avatar
New User
sounds like a loose vacuum line, or it might be the Idle Air Control Valve...
Old Nov 5, 2001 | 05:16 AM
Phatwhippin_CRX's Avatar
Default Re: erratic idle on ls swap? (HyperREV)
My guess is a vacuum line, as long as it's not throwing any codes...........
Old Nov 5, 2001 | 07:57 AM
B18b Turbo's Avatar
New User
Default Re: erratic idle on ls swap? (Phatwhippin_CRX)
ITS THE IAC I HAD THE SAME EXACT PROBLEM WITH MY LS SWAP IF YOU WANT SPECFIC DETAILS GIVE ME A CALL AND IL EXPLAIN 757 422 0910
Old Nov 6, 2001 | 11:12 AM
Mazmay's Avatar
Default Re: erratic idle on ls swap? (LS CRIX)
could be a ground...that was the case with my crx it seems.
Old Nov 6, 2001 | 05:13 PM
HyperREV's Avatar
New User
Default Re: erratic idle on ls swap? (Mazmay)
hey maz, is the car behaving now?
Old Nov 6, 2001 | 07:15 PM
crux131's Avatar
Thanks everyone, these replies help narrow down the search, I'm going to try and straighten it out this weekend.
Ryan Detwiler
Feb 3, 2013 03:44 PM
G. Man
Classic Hondas
Jun 25, 2011 07:48 PM
durfeec
Jun 30, 2008 12:03 PM
Spec R
Apr 8, 2004 10:26 AM
6969crx6969
Feb 29, 2004 02:59 PM
