How to Removing EG Door panel?? I searched ! pics!!
Old May 7, 2004 | 11:34 AM
Daniel_san's Avatar
Default How to Removing EG Door panel?? I searched ! pics!!
ok, I searched, and found lots of info, but it makes no sense
I found the 3 screws and unclipped all the clips, but the door handle is in the way. so then I searched again, and I read something about a pin hold somewhere, but have no idea where it is.
please help me get my door pane off, it looks like this now
inside of door
Old May 7, 2004 | 11:36 AM
nerdsports's Avatar
Default Re: How to Removing EG Door panel?? I searched ! pics!! (Daniel_san)
theres a clip behind the window handle... its like a U sorta, but more closed... you can use a thin flathead screwdriver or needle nose pliers. try not to lose it either hehe. good luck.
Old May 7, 2004 | 11:38 AM
fakemike's Avatar
There is a wire clip that holds the window crank on. I made a sort of hook out of a wire hanger to remove mine. You can see it if you look closely.
Old May 7, 2004 | 11:40 AM
Synergy001's Avatar
yea....take the clip that is hold the window crank off. you can use a thin screwdriver and push it off. also, some people say you can use a comb
Old May 7, 2004 | 11:44 AM
satitus's Avatar
Easiest way to remove a window crank is to work a towel in behind the crank and move the towel back and forth. Works every time in about 2-3 seconds. Learned it from a dude at a junkyard
Old May 7, 2004 | 11:46 AM
Daniel_san's Avatar
Default Re: (Synergy001)
I really can't see the clip. is it in between the door and door panel or is it where the crank is on the outside ?
and if it's inside, the only place I can think of has a big foam piece surrounding the inside part of the crank, and the panel is too tight and I can't really see anything
Old May 7, 2004 | 11:48 AM
Synergy001's Avatar
Default Re: (Daniel_san)
put the door panel back on and the push on the door panel a lil so you can see between the door crank and panel. turn the crank until you can see the ends of the clip. its sorta like a "U" shape. turn it until you see the top of the "U" shape then try to pry it off.
Old May 7, 2004 | 12:07 PM
Daniel_san's Avatar
sorry, it was very hard to take a picture and hold the panel at the same time.
but, I still can't find the clip
I found a ring, but it seems to be rubber.
Old May 7, 2004 | 12:12 PM
satitus's Avatar
Just slide a thin towel between the crank and the panel. Move the towel around the crank and it will very quickly catch on the pin holding the crank. Pin should pop off. You may want to pop the panel back in place so it isn't putting pressure on the pin.
Old May 7, 2004 | 12:19 PM
Jonny G.'s Avatar
You have the right idea about placing a flathead screwdriver behind the window crank. The "U" shaped pin that everyone is talking about is behind that thin plastic thing between the door panel and the crank itself.
What you wanna do is take the screwdriver and wedge it between the plastic thing and turn the window crank up or down, eventually one side of the "U" pin will catch the screw driver and will pop out.
Usually the bottom of the "U" pin will show and after that you can just pull it off the handle. Once you get this, it'll be easier on the other door. Good luck!
Old May 7, 2004 | 12:27 PM
Tad's Avatar
Tad
haha that clip is a pain in the *** if you've never seen it before,
basically, try and look under that handle the best you can, if you see ANYTHING METAL , that is part of your clip!
its the only metal piece in there.
you just got findi t, get a good grip on it, and yank it out.
Old May 7, 2004 | 12:34 PM
Ricey McRicerton's Avatar
Default Re: (Tad)
Slide the panel back up to it's original position. Take a pair of angled forceps (a medical supply) and push them out. That is by far the easist thing I've ever used.
Old May 7, 2004 | 12:39 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: (Tad)
I just re-did this after not doing it for quite some time.
One, place the panel as close to the original position as possible. Turn the window crank so the handle is facing you, make sure you have good light to be able to see the metal clip. Now there are going to be two metal edges popping up. Place a flathead screwdriver on the one to right so that when the clip flies off it has a better chance of landing in the car. Push the flathead screwdriver down and away from the center of the window crank. Once the clip flies off place it in the driver seat and pull the door lever as if trying to open the door and remove the screw from behind the handle. From the picture you listed, everything should be accessible to pull the door panel up and around the handle to get it off the door.
Old May 7, 2004 | 12:41 PM
The AntiRice's Avatar
you just have to push thedoor panel in farther to reveal the clip. it should be a bronze color and be somewhat shaped like a letter "u". It should be fairly obvious...
google
http://www.carstereohelp.com/i...7.JPG
http://home.earthlink.net/~goodspeeds/CRANK.HTM
Old May 7, 2004 | 12:42 PM
slowhatch4now's Avatar
Default Re: (Ricey McRicerton)
here you go dude
i kno its kinda a shitty diagram but hey its something
hopefully that helps, you have to yank at the top of the Omenga looking thing
peace
Old May 7, 2004 | 12:43 PM
Default Re: (slowhatch4now)
Good to see you guys helping out with a fairly simple question instead of flaming. What the hell does the picture of the crown vic have to do with this thread?
EDIT: Fixed, you caught it before I could get my stuff up.
Old May 7, 2004 | 01:09 PM
swifty4u's Avatar
What i found easy is to take one flathead screwdriver, and try to find the end of the metal U-clip. When you find it place the one screwdriver on it and get another flathead and find the other clip, then just push on both. It may fly off, or just push off enough until you can grab it.
Old May 7, 2004 | 02:26 PM
dantastic's Avatar
i just used 2 flat blade screw drivers to pop the clip off... its really easy after uve done it once
Old May 7, 2004 | 03:25 PM
Ski11z's Avatar
Default Re: (dantastic)
Takes seconds when you've done it before and you have the correct tool to do the job.
see the mechanics of the pin actually on the backside of the handle?
Old May 7, 2004 | 03:29 PM
jcarothers's Avatar
when you get it out, remember how you put the clip in so next time you know which side of the handle the open end is on
Old May 7, 2004 | 05:28 PM
Daniel_san's Avatar
Default Re: (jcarothers)
thanks, that last picture really helped
I'll try this **** right now
Old May 7, 2004 | 05:32 PM
crazy eyez killa
Guest
Posts: n/a
whoa 99-00 doesnt have that...
edit: oops i have power windows
X93siX
Jan 30, 2010 05:34 PM
SLURS
13
Jun 18, 2009 01:39 AM
pompom
Feb 28, 2006 04:41 PM
DRAG1320ciVHBKsi
Nov 29, 2002 09:50 AM
serious
Sep 6, 2002 04:40 PM
