h23 alternator on jdm h22 engine?
Old May 7, 2004 | 10:45 AM
1hotcivicSi's Avatar
Default h23 alternator on jdm h22 engine?
will the h23 alternator fit on my h22 ? if not does anyone have a h22 alternator they are selling?
Old May 7, 2004 | 11:37 AM
Default Re: h23 alternator on jdm h22 engine? (1hotcivicSi)
john stop using my name.... h23 altenator is so differnt your gunna have to spend another 1000$$ for the jdm one sorry
Old May 7, 2004 | 02:12 PM
blackdelslo's Avatar
$1000 huh? Is that the one that comes completely made of 24k gold?
Old May 7, 2004 | 03:39 PM
md23vtec's Avatar
YES it will work.
Old May 7, 2004 | 04:52 PM
Default Re: h23 alternator on jdm h22 engine? (md23vtec)
are u sure sure it will work or are u just assuming
Old May 8, 2004 | 09:00 AM
93H22ACX's Avatar
it'll work. i had one on my h22.
Old May 8, 2004 | 09:20 AM
fastludeh22's Avatar
Default Re: h23 alternator on jdm h22 engine? (95PRELUDEVTEC206)
you will have to change pullys on it....the belts use different about of ribs
Old May 8, 2004 | 03:03 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">are u sure sure it will work or are u just assuming
IT WILL WORK. You can use your h23 belts just use the crank pulley off the h23. That way u do not have to change anything as far as any belts or pulleys
Old May 9, 2004 | 05:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">
IT WILL WORK. You can use your h23 belts just use the crank pulley off the h23. That way u do not have to change anything as far as any belts or pulleys</TD></TR></TABLE>
are they the same size/weight?
Old May 9, 2004 | 01:52 PM
md23vtec's Avatar
Default Re: h23 alternator on jdm h22 engine? (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">
are they the same size/weight?</TD></TR></TABLE>
WTF! They will work the weight will not vary that much if any
Old May 9, 2004 | 02:08 PM
WTF! They will work the weight will not vary that much if any </TD></TR></TABLE>
chill out man...i didnt say they wouldnt work....i was asking for a compleat different reason.
if you want to know, 90-91 b18a crank pully is slightly smaller and a little lighter, then 92-93. i put one on my gf's 92 when i changed t-belts. it has somewhat of the same effect as aftermarket crank pully, but still retains stock damping capabilitys.
i was going to see if this can be done on h22/23...
Old May 9, 2004 | 02:17 PM
md23vtec's Avatar
h23vtec_dc2
Sep 14, 2008 02:11 PM
pkolaboy
Jun 27, 2008 06:47 PM
AdReNaLiN
Feb 28, 2008 04:00 PM
96SinisteR_Lude
Oct 17, 2007 10:34 PM
snowblind7x
May 13, 2007 11:51 PM
