NEED HELP w/rear sway install...
Old May 7, 2004 | 10:19 AM
MASTRCHANN's Avatar
Default NEED HELP w/rear sway install...
civic si rear sway bar for my 00 ex. here's what i got:
EXACTLY what else will i need? i checked the diagram from hondaautomotiveparts.com and there is some sort of stabilizer bracket, so i'm gonna need two of those. but as far as any other nuts or bolts, i have only four bolts for the D brackets. I'm looking to order everything else today, so any help would be GREATLY appreciated.
Old May 7, 2004 | 10:33 AM
CRITTERMATT's Avatar
Default Re: NEED HELP w/rear sway install... (MASTRCHANN)
You are going to need the two brackets that attach to the frame and 4 bolts to attach them. go to http://www.slhondaparts.com and look at the exploded view to see what you need.
Old May 7, 2004 | 10:39 AM
MASTRCHANN's Avatar
Default Re: NEED HELP w/rear sway install... (CRITTERMATT)
thanks.
Old May 7, 2004 | 10:41 AM
Np. i hope that link helps you.
Old May 7, 2004 | 11:10 AM
TurboBumblBee's Avatar
wont you also need new lower control arms as well?? or did the EX come w/ mounts for the rear sway bar?
Old May 7, 2004 | 11:32 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: NEED HELP w/rear sway install... (Boostfedb18c1)
doesn't an EX come equipped with a rear sway bar already?
Old May 7, 2004 | 11:56 AM
96ex's Avatar
Default Re: NEED HELP w/rear sway install... (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">doesn't an EX come equipped with a rear sway bar already?</TD></TR></TABLE>
Nope mine doesn't have one...but you don't need the lower controll arms cause it already has the mounts
supermeister
Jan 4, 2009 08:26 PM
coupej1
Suspension & Brakes
Oct 13, 2008 06:26 AM
turnsignalandy
Nov 24, 2006 04:25 PM
Vantage
Honda Civic (2001 - 2005)
Jul 26, 2006 09:01 PM
95integragsr1984
May 25, 2003 09:26 PM
