Is this a 1" MC? Picture.
Old May 7, 2004 | 07:53 AM
Jonathan_ED3's Avatar
Default Is this a 1" MC? Picture.
Came off of a '98 GSR w/ABS. That's the only number I see on the MC, but people have told me the size marking is on the OTHER side of the MC.
I've tried searching but some threads say only the ITR has a 1" MC while the Integras with ABS are slightly smaller, but then others say the 98+ Integras with ABS all have a 1" MC.
The other side just has a B C 5 and then Honda.
TIA for this seemingly simple question.
Old May 7, 2004 | 07:56 AM
Nextelbuddy's Avatar
Default Re: Is this a 1" MC? Picture. (Jonathan_EH)
you see that big <FONT SIZE="10">1</FONT> ?
yup thats it
Old May 7, 2004 | 08:47 AM
Turbo E's Avatar
now will it fit on an EG?
Old May 7, 2004 | 08:55 AM
Default Re: (Turbo E 604)
not unles you swap out the matching brake booster, and even then youneed to reflare i beleive one of the lines unless you are really good t carefully bending brake lines to get it to the new position on the m/c
Old May 7, 2004 | 08:59 AM
eg crunkmonster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">now will it fit on an EG?</TD></TR></TABLE>
It fit in my EG hatch...All we did was swap out the MC and BB and then bend one of the lines carefully to make it fit
Old May 7, 2004 | 09:18 AM
Derek14's Avatar
Default Re: (eg cookiemonster)
from a GSR? thats an ITR MC/BB combo...
Old May 7, 2004 | 09:31 AM
carsaregood's Avatar
Default Re: (Derek14)
that looks exactly like the mc/bb combo i have in my car. check the two threaded holes, they will either be one 10 mm, and one 12 mm. OR both will be 10 mm. If they are both the smaller size, you're in luck and won't have to reflare your lines, all you need to do is bend them which is pretty easy.
my mc/bb is from a '99 gsr
Old May 7, 2004 | 10:01 AM
Okininam's Avatar
Default Re: (carsaregood)
out off all places, he shoots the m/c on the bed. thats gangster
Old May 7, 2004 | 10:57 AM
Default Re: Is this a 1" MC? Picture. (NextelBuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NextelBuddy &raquo;</TD></TR><TR><TD CLASS="quote">you see that big <FONT SIZE="10">1</FONT> ?
yup thats it</TD></TR></TABLE>
Thanks for the help
I was just double checking because on my EF the number is on the left side of it, and I just wanted to double check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Derek14 &raquo;</TD></TR><TR><TD CLASS="quote">from a GSR? thats an ITR MC/BB combo...</TD></TR></TABLE>
I pulled this myself off of a '98 GSR w/ABS.
I was under the idea that the 98+ Integras with ABS had the same setup as the ITR.
Is this not the case?
Old May 7, 2004 | 11:29 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (Okininam)
you're better off just finding an integra RS master cylinder/brake booster or a 91 civic EX. they're both 15/16" and you don't have to hassle with rebending and reflaring brake lines.
Old May 7, 2004 | 11:30 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (AzntaggeR)
oh sorry, i was trying to answer Turbo E 604s question.
AK94GSR
Jul 9, 2015 03:35 PM
Ohio
Sep 29, 2010 11:30 AM
tougetuned_ef
Jun 29, 2010 03:09 PM
vtac sonn
May 19, 2007 07:47 AM
nikolai.
12
Nov 12, 2006 08:51 AM
