help! too low now
Old May 6, 2004 | 06:42 PM
deviant1's Avatar
Default help! too low now
arghhh. i bought H&R race spring for my ek hatch and it slammed it. my tires rub all the time and when i turn. we are not talking about a high speed turn, im talking about making a turn slowly in a parking lot. any way i can fix this? i know most will say get coilovers or get new springs. just looking for some opinions. i have 16" rims by the way (205/45/16 tires).
Old May 6, 2004 | 06:47 PM
JDM PRO's Avatar
Default Re: help! too low now (deviant1)
you might have a wrong offset
Old May 6, 2004 | 07:20 PM
FERIOkid's Avatar
Default Re: help! too low now (JDM PRO)
what kind of shock/strut set up you got? if they are stock that could be contributing to your problem
Old May 6, 2004 | 07:21 PM
sshaikh01's Avatar
you can roll your fenders
Old May 6, 2004 | 07:22 PM
deviant1's Avatar
Default Re: help! too low now (slowdx9585)
i have h&r race with tokico illuminas. what about coil spacers? smaller tire (205/40/16 instead of my current 45)? maybe smaller rims like 15s?
Old May 6, 2004 | 07:23 PM
deviant1's Avatar
Default Re: help! too low now (sshaikh01)
rolling my front fenders wouldnt do much. i was looking at where it left rub marks on the fender liner and even if i did roll them, it might still rub. i know there is a place above the tire that rubs along with the sides of the tire.
Old May 6, 2004 | 07:26 PM
CivicFerioSiR's Avatar
do you rub on the actual fender itself? because i wouldnt worry too much about small amounts of rubbing on the plastic inner fender cover. i rub my 14"s on my fenders but its worth the slammed look.
Old May 6, 2004 | 07:52 PM
deviant1's Avatar
Default Re: help! too low now (CivicFerioSiR)
i rub the plastic inner fender shield. the plastic clip at the top most part of the fender arch is all messed up.
Old May 6, 2004 | 09:17 PM
sshaikh01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">i rub the plastic inner fender shield. the plastic clip at the top most part of the fender arch is all messed up.</TD></TR></TABLE>
If i were you i wouldn't worry about it.
Its nothing. You can live without that plastic.
Old May 6, 2004 | 09:50 PM
North_Texas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 &raquo;</TD></TR><TR><TD CLASS="quote">
Its nothing. You can live without that plastic.</TD></TR></TABLE>
I also just removed my plastic. Well it feel off many different times from different areas. But anyways, it shouldn't big deal to remove it, but some might argue differently. If it is still rubbing, I'd suggest smaller tires.
Old May 6, 2004 | 11:44 PM
mycivicstoo(s)low's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">you might have a wrong offset</TD></TR></TABLE>
Really, what's the offset of your wheels?
Old May 6, 2004 | 11:51 PM
Shawn C's Avatar
In The Garage
that'd be my guess too, or maybe too much camber correction???
Old May 7, 2004 | 01:11 AM
slammed_93_hatch's Avatar
take that **** out, or cut the top section of it out.
unless you live in a high rust **** area, but if you do likely hood is ur ***** already rusted
Old May 7, 2004 | 01:56 AM
deviant1's Avatar
Default Re: help! too low now (slammed_93_hatch)
i have 205/45/16 tires with rotas. offset is 42 i THINK. not sure. no camber kit because that would make it worse.
how would you describe a rust prone area?
i want to take off the plastic lining, but im scared the tire will rub on the metal fender lip or the edge of metal that sticks down from above the center of the tire. if i remove the plastic, then it will scrape the metal. will the wheel travel high enough to hit that? will taking out the plastic fender lining cause rust or extra dirt in the engine bay? any negative side effects to removing it?
Old May 7, 2004 | 04:54 PM
deviant1's Avatar
bump
would a 205/50/15 tire be better? what about 195/50/15?
Old May 8, 2004 | 09:27 PM
ya, nothing is gonna happen if you rub a little on small amounts of plastic. what do you think will happen?
Old May 9, 2004 | 09:36 AM
Kevedge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">i have 205/45/16 tires with rotas. offset is 42 i THINK. not sure. no camber kit because that would make it worse.
i want to take off the plastic lining, but im scared the tire will rub on the metal fender lip or the edge of metal that sticks down from above the center of the tire. if i remove the plastic, then it will scrape the metal. will the wheel travel high enough to hit that? will taking out the plastic fender lining cause rust or extra dirt in the engine bay? any negative side effects to removing it?</TD></TR></TABLE>
Just go ahead and take the plastic out. Do you honestly think that this peice of plastic is keeping you from rubbing on the metal clip? No. If i think its the clip your talking about (right on the edge of the fender) You can just bend it up and that shoudl stop you from rubbing on it. With the fender lining out, it wont cause anymore dirt inside your engine bay, but you will cause more dirt inside of your wheel wells, and in the door cracks. It really isnt that big of a deal, in my opinon atleast.
Old May 9, 2004 | 09:39 AM
pdiggitydogg's Avatar
buy new springs and sell those
Old May 9, 2004 | 09:41 AM
aphex23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioSiR &raquo;</TD></TR><TR><TD CLASS="quote">ya, nothing is gonna happen if you rub a little on small amounts of plastic. what do you think will happen?</TD></TR></TABLE>
well, i would guess it would be annoying as hell for one..
i like a nice quite ride when im driving.. other than the sound of the engine and exhaust
Old May 9, 2004 | 11:06 AM
REDGEAR's Avatar
Do you have rear camber kits? If you do then you might want to get shorter LCAs like the SPC since they give you more clearance. You should be alright with the 16s but use 40 offset. Goodluck.
NemesisCBR
Jun 28, 2011 02:00 PM
Lauj87
Mar 5, 2006 08:55 AM
XX Boosted Si XX
Sep 2, 2005 10:40 PM
Vtecfool
Oct 20, 2003 04:51 AM
Thrillhouse
Sep 28, 2003 10:30 PM
