99-00 Si Wheels with Red Rays Lug Nuts
Anyone have this set up with pics? Possibly on a red car? Maybe a red Integra? But anything will do as long as they are 99-00 si with red rays lug nuts or even black rays lug nuts...
searched...nothing...
can some1 help me out?
Modified by Gr8GrZ at 6:06 AM 5/7/2004
dont know if its just what i heard, but someone said not to run oem wheels with aftermarket lug nuts, and vice versa
correct me
correct me
^^^ you are correct...my homie was gonna place some aftermarket lugnuts on his gsr clovers, but the guy at the shop sed that it wouldnt fit correctly...since either the lugnuts or the studs on the hub are more narrow than the other or vice versa...something like that
you CAN run aftermarket lugnuts on oem wheels as long as they taper, ive had kyokugens on my ls meshs for 2 years now with no problems. ive removed them numerous times. its the oem lugnuts that you shouldn't run on aftermarket wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deka »</TD></TR><TR><TD CLASS="quote">you CAN run aftermarket lugnuts on oem wheels as long as they taper, ive had kyokugens on my ls meshs for 2 years now with no problems. ive removed them numerous times. its the oem lugnuts that you shouldn't run on aftermarket wheels.</TD></TR></TABLE>Agreeed. My friend uses aftermarket lugnuts on his ITR rims.
There are tapered ones and there are ones that are rounded. OEM ones are rounded.
The one on the right is the rounded kind. The other two have the straight taper.
And being that I work in a dealership and from what I have heard its best to match taper with taper and rounded with rounded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 »</TD></TR><TR><TD CLASS="quote">There are tapered ones and there are ones that are rounded. OEM ones are rounded.
And being that I work in a dealership and from what I have heard its best to match taper with taper and rounded with rounded.</TD></TR></TABLE>
FR-MOB: ThE bEe GuY
Jul 1, 2003 08:38 AM
