Ignition Pulse Question
Old May 6, 2004 | 06:21 PM
JDMmaster's Avatar
Default Ignition Pulse Question
I am preparing to build a digital tach using a microcontroller (PIC MICRO for those who know what that is) anyways, i am having a hard time obtaining an oscilloscope (expensive as ****) to hook up to an ignition (blue wire) to figure out the signal. My question is: how many pulses are there per revoltion and the max voltage of each pulse.
Thanks in advance...
Old May 6, 2004 | 08:58 PM
PHiZ's Avatar
Default Re: Ignition Pulse Question (JDMmaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMmaster &raquo;</TD></TR><TR><TD CLASS="quote">I am preparing to build a digital tach using a microcontroller (PIC MICRO for those who know what that is) anyways, i am having a hard time obtaining an oscilloscope (expensive as ****) to hook up to an ignition (blue wire) to figure out the signal. My question is: how many pulses are there per revoltion and the max voltage of each pulse.
Thanks in advance...</TD></TR></TABLE>
There are other sensors to take the signal off of. Like the Crank Position Sensor, which is two pulses per revolution.
A sensor signal might be less noisy (with proper ground) than an ignition signal.
-PHiZ
Old May 7, 2004 | 08:36 PM
JDMmaster's Avatar
Default Re: Ignition Pulse Question (PHiZ)
So what kind of signal is present on the tach wire (blue)?
zenon8890
Audio / Security / Video
Aug 1, 2007 11:32 PM
xstr8ballinx23sd
Nov 22, 2004 07:59 PM
Del
May 3, 2003 10:17 AM
