will any other key fit kyokugens????
Old May 6, 2004 | 06:18 PM
IS3Fifty's Avatar
Default will any other key fit kyokugens????
you guessed it another kyokugen key breaking!!. Anyway, I was looking at several different keys and the gorrilla seems to be almost identical. I wanted to see if someone else had any prior experience with using a different key.
I did a search and only got useless addage.
Old May 6, 2004 | 06:31 PM
hatchdrvr's Avatar
Default Re: will any other key fit kyokugens???? (TODAeg6)
no
Old May 6, 2004 | 06:35 PM
skip.two's Avatar
call kyokugen, and try to get another copy. i think thats the only way. unless you want to call AAA all the time just to get your wheels off.
Old May 6, 2004 | 06:37 PM
IS3Fifty's Avatar
Default Re: will any other key fit kyokugens???? (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">call kyokugen, and try to get another copy. i think thats the only way. unless you want to call AAA all the time just to get your wheels off.</TD></TR></TABLE>
they will send me just another copy of the key?? I thought about getting a machine shop to make me a sturdy one.
Does kyokugen have a webpage ( I looked to no avail)?whats the number?
Old May 6, 2004 | 06:46 PM
skip.two's Avatar
well i'm not sure if they will send you another one. i just figured that all companies that make rim locks, should send you another key. they expect their buyers to depend on one key? thats crazy. check the box that they came in, maybe there's a number on there.
Old May 6, 2004 | 07:57 PM
IS3Fifty's Avatar
its all in japanese!
I've looked for a webpage, like I said. No luck.
I'll probably just see if someone can go ahead and machine one for me
Old May 6, 2004 | 08:16 PM
skip.two's Avatar
well whatever works. goodluck
Old May 6, 2004 | 08:18 PM
SOHC_MShue's Avatar
yea my key looks like its getting worse and worse
Old May 6, 2004 | 08:22 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">you guessed it another kyokugen key breaking</TD></TR></TABLE>
if you didnt torque the key/lugs so much then the key/lugs wouldnt strip and or break.. funny thing, i've taken my wheels on and off for over a year with my kyokugen lugs, and i've never had a problem.
call kyokugen and see if they will send you a new key.. if not then find a way to get them off and dont ever use them again.
Old May 6, 2004 | 08:35 PM
IS3Fifty's Avatar
Default Re: will any other key fit kyokugens???? (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">
call kyokugen and see if they will send you a new key.. if not then find a way to get them off and dont ever use them again.</TD></TR></TABLE>
I didnt break the lugs.... the key is made of thin aluminum,Bullshit, it should be cast. what socket or wrench isnt at least cast, most are case hardened.
The design is ****, eventually even the most careful user is going to wear it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">yea my key looks like its getting worse and worse </TD></TR></TABLE>
Everyone keeps saying to call Kyokugen, but how when there is no # or webpage?
Old May 6, 2004 | 08:41 PM
IS3Fifty's Avatar
why cant they give you a socket like this: https://honda-tech.com/zerothread?id=854152
Hatchtrap's Avatar
man what a crappy design
Old May 6, 2004 | 08:43 PM
IS3Fifty's Avatar
Default Re: (Hatchtrap)
yeah your telling me. The lugs are good dont get me wrong, but geez cheapo one of the most important parts
Old May 6, 2004 | 09:26 PM
second edition's Avatar
Default Re: (TODAeg6)
if all else failes, you could buy a new set of lugs which would come eith a new key, corect?
Old May 6, 2004 | 09:49 PM
IS3Fifty's Avatar
Default Re: (second edition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by second edition &raquo;</TD></TR><TR><TD CLASS="quote">if all else failes, you could buy a new set of lugs which would come eith a new key, corect? </TD></TR></TABLE>
yeah but thats a waste of money
Old May 7, 2004 | 06:44 AM
98 blacksh's Avatar
awe thats shitty hows the new hatch?
Old May 7, 2004 | 07:33 AM
stockegsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">yeah but thats a waste of money</TD></TR></TABLE>
or you can barrow the key from somebody, im sure there are still peeps here that uses kyokugen. If you were local i'll let you use my key. BTW, ive had mine for over a year and ive taken my rims numerous times and i always use a torque wrench, never had a problem.
Old May 7, 2004 | 08:37 AM
IS3Fifty's Avatar
Default Re: (stockegsix)
yeah, Im trying to find someone with them now.
Old May 7, 2004 | 09:57 AM
HyBriDcxR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">why cant they give you a socket like this: https://honda-tech.com/zerothread?id=854152</TD></TR></TABLE>
You don't get that socket cause look at the price different.
If you were local i'd let you borrow it.
Old May 7, 2004 | 10:25 AM
eg6ajk's Avatar
you can try to jam 15-16mm 12point socket inthere, should work
Old May 7, 2004 | 10:33 AM
ebp 99 si's Avatar
Default Re: will any other key fit kyokugens???? (eg6ajk)
mine rounded off in the end
i ordered another key from a website
http://store.yahoo.com/urbanim....html
it was 20 with shipping
or i also found out that 1 of my nuts was also rounded so i had to hammer a 15mm 12pt socket on it and get if off that way
luckily i had an extra lug nut
Old May 7, 2004 | 11:19 AM
IS3Fifty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">you can try to jam 15-16mm 12point socket inthere, should work</TD></TR></TABLE>
yeah should work, but then I have a junked lug and socket. basically, I just want to be able to torque the lugs. I dont really want to take them off right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebp 99 si &raquo;</TD></TR><TR><TD CLASS="quote">mine rounded off in the end
luckily i had an extra lug nut</TD></TR></TABLE>
Wow, $20 shipped thats pretty spendy. Im still looking into getting one machined. the broken one was welded today, so I will see if they fixes the problem.
Old May 7, 2004 | 11:23 AM
-Gambit-'s Avatar
i got mine off with like a 9/16th wrench but you need to be careful not to scratch your wheel.
ebp 99 si's Avatar
yeah it was kinda of expensive but it's better than buying the whole thing with new lugs
the best part was that my old one wasn't that bad it was just that 1 rounded off nut
so now i have 2 good lug tools
Old May 7, 2004 | 11:24 AM
dantastic's Avatar
my bro jammed a 17mm 6pt socket on one of my kyogens before. he didnt kno they were special lugs when he was taking them off =P. good thing i have 4 lug, and i have 4 extra lug nuts =P. btw, the kyogen "key" isnt really a key, its just a 7-sided 17mm socket
