need quick answer or Opinions...shiflinkage...
Old May 6, 2004 | 04:18 PM
TIRENECK's Avatar
Default need quick answer or Opinions...shiflinkage...
what could make the shift linkage not fit almost perfect? the mount on the crossmember? or the braket? I think it might be the braket cause I had two, one was from an automatic and the other from a manual. It is not shift linkage error because the whole swap came off the same year integra. The problem is that my gears in the shifter are not centered, the gears sit all the way to the back.
lets say this is a normal shifter (------), the dashes means neutral, my neutral is here (_ _ _ _ _). what i was about to do is cut the shift linkage but if its the braket doing this I can replace it.
Old May 6, 2004 | 04:34 PM
doublejz's Avatar
Default Re: need quick answer or Opinions...shiflinkage... (TIRENECK)
need more info, what was an auto/man the bracket? the car was an auto to man conver?? me confused
Old May 6, 2004 | 06:30 PM
TIRENECK's Avatar
Default Re: need quick answer or Opinions...shiflinkage... (doublejz)
well if your confused you have a problem of your own. I have two brakets one was from a automatic and the othe was manual. would the braket matter in this problem? The car was never a automatic and the shift linkage came with the whole swap from the same year integra.
Old May 7, 2004 | 04:48 PM
JSJ EG6's Avatar
need to know also.
Old May 7, 2004 | 08:25 PM
TIRENECK's Avatar
Default Re: need quick answer or Opinions...shiflinkage... (JSJ_EG_HATCH)
bump.
Old May 7, 2004 | 08:30 PM
StyleTEG's Avatar
You need to explain better, your post makes little to no sense.
Which bracket? The one that holds the shifter itself, or the one that bolts the shift linkage to the chassis?
Old May 7, 2004 | 08:54 PM
TIRENECK's Avatar
Default Re: need quick answer or Opinions...shiflinkage... (StyleTEG)
back of the motor braket, my fault.
Old May 7, 2004 | 09:01 PM
Sliced Beard's Avatar
you should be using the longer of the two brackets
one has a slightly larger offset between the tranny mount bolts and the crossmember mount.
sounds to me like you have the auto bracket in there
Rease3
Dec 8, 2009 02:35 PM
m0squ1t0
16
Sep 17, 2009 11:06 AM
OldMajor
Jun 19, 2009 10:49 PM
hatchet_man16
May 7, 2009 11:23 PM
xkrazyxjbrkerx75
Oct 19, 2008 01:27 PM
