Problem mainting pressure while turning
Old May 6, 2004 | 03:10 PM
sshaikh01's Avatar
Default Problem mainting pressure while turning
I have a 96 civic ex
Car sat and ate dust for 1 year. I'm now driving it, Everytime i cut the streeling wheel all the way no matter which side, the master cyl. looses pressure, i pump the brake pedel a couple of times and the pressure is there again, and i don't loose pressure untill i make a U turn, or just turn the wheel to the sides.
Old May 6, 2004 | 04:49 PM
sshaikh01's Avatar
Default Re: Problem mainting pressure while turning (sshaikh01)
ttt
Old May 6, 2004 | 09:25 PM
sshaikh01's Avatar
Old May 7, 2004 | 01:06 PM
sshaikh01's Avatar
hello
Old May 15, 2004 | 10:56 AM
sshaikh01's Avatar
bump
Old May 15, 2004 | 11:10 AM
elwood's Avatar
up for a weird problem.
I didnt even know the two were related.....
Old May 15, 2004 | 11:16 AM
Street Ghost's Avatar
Default Re: Problem mainting pressure while turning (elwood)
Probably something is wrong with your brake lines. Maybe there's like a small tiny hole in them and when you steer one way, it stretches the line and the hole, making you lose pressure when you step on the brakes.
I'm not sure what the problem really is, just taking a guess.
Old May 15, 2004 | 11:24 AM
sshaikh01's Avatar
Default Re: Problem mainting pressure while turning (JDM Ninja)
i don't think there is a hole, because there are no oil droppings anywhere
Old May 15, 2004 | 12:25 PM
triggerX's Avatar
Check the vacuum lines that plug onto the brake booster and make sure they are tight and that there are no leaks. Check the fluid level and refill to required level.
Old May 15, 2004 | 05:16 PM
sshaikh01's Avatar
Default Re: Problem mainting pressure while turning (1Chance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Chance &raquo;</TD></TR><TR><TD CLASS="quote">Check the vacuum lines that plug onto the brake booster and make sure they are tight and that there are no leaks. Check the fluid level and refill to required level. </TD></TR></TABLE>
No leaks, and the fluid level is not going down.
Old May 15, 2004 | 05:21 PM
ekb18cCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 &raquo;</TD></TR><TR><TD CLASS="quote">
No leaks, and the fluid level is not going down.</TD></TR></TABLE> check the lnes for dry rot.. if your losing pressure it hs to be getting out from somewhere ..
Old May 15, 2004 | 05:32 PM
Luserkid's Avatar
Default Re: Problem mainting pressure while turning (ekb18cCivic)
Turn the wheel all the way one way and press the brakes to where you loose the pressure.
Get out and check for leaks.
Do it again but turning the other side.
Because the car sat for a year i think when you turned the wheel you stretched the lines when they werent use to being stretched. So i think you have some cracks, maybe even air in the lines.
Old May 15, 2004 | 05:39 PM
Default Re: Problem mainting pressure while turning (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Turn the wheel all the way one way and press the brakes to where you loose the pressure.
Because the car sat for a year i think when you turned the wheel you stretched the lines when they werent use to being stretched. So i think you have some cracks, maybe even air in the lines. </TD></TR></TABLE> exactly.. he is totally right.. sitting allows lines to dry out and re stretching them can cause cracks .. does as he said ... it will help better if you have someone else turning the wheel and applying the brakes... you will most likey find the problem easier
Old May 16, 2004 | 12:23 PM
sshaikh01's Avatar
Thank You
i'll try that
dcmatt
Suspension & Brakes
Sep 22, 2013 07:37 AM
scrubachu
Sep 2, 2005 03:53 PM
scrubachu
Sep 1, 2005 04:02 AM
