IAT location?????
Old May 6, 2004 | 03:03 PM
pnltnc's Avatar
Default IAT location?????
Yah, I've got a 93hatch dx with a gsr swap. I'm showing a cel, Its one long flash...I believe thats a code 10, IAT.. anyone know were this is located and can I do anything to correct it? pics would be cool. thanx in advance.
Old May 6, 2004 | 03:13 PM
SoldMyEM1's Avatar
Default Re: IAT location????? (pnltnc)
the IAT sensor is the sensor on the manifold that is located to the left of the fuel pressure regulator and right above the fuel rail...not sure what to do to correct it though..maybe get a new one?
Old May 6, 2004 | 03:18 PM
GTlvr82's Avatar
Default Re: IAT location????? (FBPsi7)
Double check your wiring to make sure you don't have a short from a bad wiring job and if the wiring is good then just replace the IAT. If that doesn't fix it then make sure your ecu isn't fucked up. You can tell if you have a burned spot on your ecu board somewhere.
sh!ft
Oct 10, 2012 08:57 PM
360eg6
Oct 27, 2009 09:19 AM
ecstacyofgold
Apr 12, 2009 06:42 AM
LisaCivic
May 27, 2004 07:28 PM
axhandler
Jun 18, 2003 08:33 AM
