o2 sensor problems, yet again
Old Nov 4, 2001 | 02:46 PM
1.8EG-T's Avatar
Default o2 sensor problems, yet again
lsvtec with preobd wiring. I have the sensor setup as to use 1 for 2(hacked it basically). Weird problem is that I get the o2 sensor code, and the car will not idle by itself, jerks violently and sputters as if it is really lean or really rich, but after driving for 4 hours at 80+ the thing acts normal, but the next morning symptoms reoccur. Can the o2 sensor actually cause this? What is even more weird is that I disconnected the knock sensor and the vtec still ENGAGED, is that even possible, thought vtec was dependent on the knock sensor, oil pressure and a something else.
Old Nov 4, 2001 | 04:56 PM
fixhondas's Avatar
Default Re: o2 sensor problems, yet again (hybridrex)
What ecu are you using? Where are the O2 sensors located?
Old Nov 4, 2001 | 05:08 PM
rioninja's Avatar
The knock sensor will throw a code, but it will not put the ECU into "limp mode".
Old Nov 4, 2001 | 05:28 PM
1.8EG-T's Avatar
Sorry, nonobd pr3, the o2 sensor is located in the factory position, using just one for both o2 pins at the ecu. Yeah, I think it was a code 2 and 23. Thanks for your help.
Old Nov 5, 2001 | 06:21 AM
1.8EG-T's Avatar
C'mon someone has to know something about this, before I get mad and buy a new motor.
Old Nov 5, 2001 | 12:08 PM
fixhondas's Avatar
Try this thread:
https://honda-tech.com/zerothread?id=50722
Wildemanam
Honda CR-V & Element
Jan 30, 2018 08:58 AM
randomracing
Dec 26, 2008 08:37 AM
Perfectionist
Oct 20, 2006 03:36 PM
vet_girl
Jan 15, 2004 03:24 PM
mickey513
Jun 2, 2002 04:42 PM
