SOHC Greddy Kit... What injectors?
Old May 6, 2004 | 10:48 AM
VTECisSeXY's Avatar
*insert here*
Default SOHC Greddy Kit... What injectors?
I'm currently running the greddy kit with stock injectors... I found a good deal on some prelude 390's. What would i need for these to work with my d16? Or better yet, what do you guys run? thanks!
Old May 6, 2004 | 10:56 AM
2muchPSI's Avatar
Default Re: SOHC Greddy Kit... What injectors? (VTECisSeXY)
I've got some RC 310's I need to get rid of, they come with Drag III kits, and are good up to 7 or 8 psi. Im me if you are interested, I can give oyu a good deal on them.
Old May 6, 2004 | 03:16 PM
Pengo's Avatar
RC310s worked nicely for me up to around 10 psi. since the sohc blue box isn't meant to control injectors that big, i also ran a walbro 255 to maintain the fuel flow and an aem fpr to turn down pressure a little.
Old May 6, 2004 | 03:28 PM
gritsak's Avatar
Default Re: SOHC Greddy Kit... What injectors? (Pengo)
if you put different injectors in then your gonna have to ditch the blue box and something to tune it with...why do you want to put diff. injectors in anyways? how much boost do you plan to run?
Old May 6, 2004 | 03:41 PM
showtymers619's Avatar
* B A N N E D *
low fuel pressure is bad ...if you can always keep the fuel pressure up for best air to fuel mixture
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pengo &raquo;</TD></TR><TR><TD CLASS="quote">aem fpr to turn down pressure a little. </TD></TR></TABLE>
CivicRaping
Apr 28, 2005 11:22 AM
CivicRaping
Apr 13, 2005 02:58 PM
MikeMAN
May 6, 2004 11:13 PM
VTECisSeXY
May 4, 2004 06:13 PM
boostincoupe
May 28, 2003 09:02 AM
