Adjusting a Hydro clutch
Old May 6, 2004 | 10:19 AM
JFG Kevin's Avatar
Default Adjusting a Hydro clutch
I know this topic been covered alot of times...i read most of them but still i'm having a hard time adjusting my clutch...i tried to adjust it from the bottom of the pedal..but as i drive it...it goes bak to the same catch point. any other way?
Old May 6, 2004 | 09:25 PM
JFG Kevin's Avatar
Default Re: Adjusting a Hydro clutch (aznstyler119)
Bump at nite
Old May 6, 2004 | 10:41 PM
shamoo's Avatar
Will you make something up for me please?
You mean hydro tranny, right?
Correct me if I'm wrong, but the only adjustment there is, is the actual position of the pedal. The engagement point will never change with a hydro tranny.
Old May 7, 2004 | 09:43 AM
JFG Kevin's Avatar
Default Re: Adjusting a Hydro clutch (shamoo)
yah..that's what i thought...i was hopin there were other wayz
Old May 7, 2004 | 09:31 PM
ACTman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if I'm wrong, but the only adjustment there is, is the actual position of the pedal. The engagement point will never change with a hydro tranny.</TD></TR></TABLE>The adjustment at the pedal that changes the engagement point is the rod going into the master cylinder. What you are doing is changing the freeplay before the rod actually moves the piston in the cylinder. If the rod engages earlier, then the arm will have more throw at the transmission. You just have to watch that you always have free play at the M/C rod or the clutch will malfunction because the self-adjusting feature (the port going to the reservoir) will be disabled. The port only opens when the m/c piston is all the way back.
allmotorkilla03
17
Jul 16, 2007 03:55 PM
spoolin_teg
Jan 9, 2007 05:52 PM
hondachris1994
Dec 4, 2006 02:58 PM
Pensar71
Jul 23, 2006 05:25 PM
f1 vtec
Oct 4, 2004 05:14 AM
