550 cc injectors good enough
Old May 6, 2004 | 09:56 AM
92_red_teg's Avatar
Default 550 cc injectors good enough
I can get a set for a real steal, is 550 cc saturanted good enough for 350 HP on a turbo setup?
Old May 6, 2004 | 09:58 AM
Lei Siew Long's Avatar
Default Re: 550 cc injectors good enough (92_red_teg)
my 550s maxxed out at 343 hp
Old May 6, 2004 | 10:07 AM
u2civic1's Avatar
do u have an upgraded fuel pump
Old May 6, 2004 | 10:11 AM
92_red_teg's Avatar
Default Re: 550 cc injectors good enough (u2civic1)
yes walbro 255
Old May 6, 2004 | 10:14 AM
FwdCivicHatch's Avatar
I wouldn't use them if I where you. Your getting them off eBay right? It's just not enough to safely run 350hp. go to http://www.importparts.com and get 650cc's atleast.
Old May 6, 2004 | 10:15 AM
92_red_teg's Avatar
Default Re: 550 cc injectors good enough (FwdCivicHatch)
thanks alot, thats what I was looking for
Old May 6, 2004 | 03:42 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_red_teg &raquo;</TD></TR><TR><TD CLASS="quote">I can get a set for a real steal, is 550 cc saturanted good enough for 350 HP on a turbo setup?</TD></TR></TABLE>
yeah sure,... they may be good enough....dont forget..two other IMPORTANT things that goes along with that....Proper tuning (does not mean callin your boyz over to see if it sounds louder by turning things here and there) and engine management .
Old May 7, 2004 | 04:44 AM
Default Re: 550 cc injectors good enough (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">
yeah sure,... they may be good enough....dont forget..two other IMPORTANT things that goes along with that....Proper tuning (does not mean callin your boyz over to see if it sounds louder by turning things here and there) and engine management .</TD></TR></TABLE>
What the hell are you talking about?
Old May 7, 2004 | 04:56 AM
FOrSfEd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FwdCivicHatch &raquo;</TD></TR><TR><TD CLASS="quote">
What the hell are you talking about?</TD></TR></TABLE>
I would also like to know.
Old May 7, 2004 | 07:30 AM
MiraiZ's Avatar
Default Re: 550 cc injectors good enough (FOrSfEd)
ran 300 w/ 450cc's...I have 560cc now and estimate that I cand do 350whp
Old May 7, 2004 | 07:39 AM
Default Re: 550 cc injectors good enough (MiraiZ)
It also depends on if your FMU or not, You should definately run the 650cc's. 550cc's are cutting it too close for comfort.
Harry Doyle's Avatar
you can definatly get the power out of them but they will probably be running one hell of a duty cycle, you should go a little bigger just to be safe..i would use 550s to make power in the low 300s not the mids...
Old May 7, 2004 | 08:53 AM
92_red_teg's Avatar
Default Re: 550 cc injectors good enough (Harry Doyle)
thanks alot for all the great replies, really appreciate it,
Old May 7, 2004 | 09:16 AM
RyanEJ8's Avatar
Default Re: 550 cc injectors good enough (Hatch4urSnatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch &raquo;</TD></TR><TR><TD CLASS="quote">my 550s maxxed out at 343 hp</TD></TR></TABLE>
You mean horsepower at the wheels, correct? 550cc should be good to about 350whp and that is at stock fuel pressure.
sfwdcrx
Apr 1, 2008 08:55 PM
Pee Wee
Jul 20, 2005 05:30 AM
DMF
Jul 10, 2005 03:23 AM
Hype__R
Jul 24, 2004 02:45 PM
avex
Jun 13, 2003 07:25 PM
