Rear sway bar question
Old May 6, 2004 | 07:54 AM
cu_jarrett's Avatar
Default Rear sway bar question
I have a 1992 civic hatchback (si) and would like to put a strong swaybar on the rear. The only problem that I can see is that there is no factory rear swaybar to use as far as mounting points. Can I still put a rear swaybar on my car with keeping the factory rear lower control arms? I planned on using the rear subframe brace also. Any help is appriciated.
Old May 6, 2004 | 08:13 AM
Daniel's Avatar
Default Re: Rear sway bar question (cu_jarrett)
Neuspeed, Progress, and Suspension Techniques show applications for all '92-'95 Civics, so I'm assuming you'll be okay. My EJ8 doesn't have a factory rear ASB, either, and my Progress installed just fine. The Suspension Technqiues Speedtech kit looks beefy, though! Looks like it comes with its own subframe bracing. http://www.modacar.com/Merchan...W.jpg
Old May 6, 2004 | 08:26 AM
Jon V's Avatar
Default Re: Rear sway bar question (Daniel)
Just get some ITR LCA's and an ITR rear sway bar with the Beaks sub-frame reinforcement kit
Old May 6, 2004 | 09:53 AM
92b16vx's Avatar
I thought the Si had a rear sway.
Old May 6, 2004 | 09:55 AM
skip.two's Avatar
you can drill a hole on your LCA's for where the sway bar will mount.
Old May 6, 2004 | 08:20 PM
cu_jarrett's Avatar
Default Re: Rear sway bar question (jL iLLuZiOnz 9)
So drilling a hole in me RLCA wont hurt anything?
Withc sway bar do you reccomend? I was thinking the cusco 26mm.
Old May 6, 2004 | 08:25 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
With what little information you've disclosed, nobody can make a judgement call on what swaybar you should run. Do a search, then maybe reply to this, saying what you're looking for.
I have a Comptech set-up, FWIW.
auto addict
Jul 6, 2008 12:47 PM
envee
Suspension & Brakes
Apr 17, 2007 09:26 PM
EK99hatch
Sep 15, 2006 07:32 AM
tinkfist
Aug 23, 2002 06:52 AM
keithv
Aug 8, 2001 09:30 PM
