engine starts revving
Old May 6, 2004 | 05:42 AM
spoon92hatch's Avatar
Default engine starts revving
This just started a couple days ago...when I first start up my car...the car rev's to about 2 grand...and stays there....then takes about 10 minutes before it idles back down to 900rpm's. Any clue on what's going on? Thanks in advance.
Old May 6, 2004 | 06:23 AM
Ya@inlinePRO's Avatar
Default Re: engine starts revving (spoon92hatch)
what did it normal stay at before when it was cold?
Old May 6, 2004 | 07:11 AM
1hotcivicSi's Avatar
normal
Old May 6, 2004 | 07:16 AM
JimmyAtlantis's Avatar
Default Re: engine starts revving (1hotcivicSi)
How's the tension of your throttle cable? Try cleaning your IACV (idle air control valve) and throttle body.
Old May 6, 2004 | 08:24 AM
stella99si's Avatar
check your vacuum lines, something might be disconected
Old May 6, 2004 | 09:52 AM
Default Re: engine starts revving (stella99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stella99si &raquo;</TD></TR><TR><TD CLASS="quote">check your vacuum lines, something might be disconected</TD></TR></TABLE>
That would give him an erratic idle
Old May 6, 2004 | 10:01 AM
Default Re: engine starts revving (JRI94)
thanks for the replies guys...I'll trying cleaning the IACV and TB
Old May 6, 2004 | 10:14 AM
otakueric's Avatar
how do you clean the tb?
Old May 6, 2004 | 10:31 AM
519[H]Si's Avatar
i had the same problem in my Hatch turned out it was just my alternator belt and it made my engine run retardly stupid.
Old May 6, 2004 | 11:00 AM
Default Re: (EG9_519)
here's another crazy problem it's doing.......when I let the clutch out...the rpms's pick up about 500 rpm's.....
This has me mind-boggled
Please help
Old May 6, 2004 | 03:42 PM
Default Re: (spoon92hatch)
Old May 6, 2004 | 04:26 PM
spoonbenny's Avatar
Default Re: engine starts revving (otakueric)
Take that bitch, out and get some throttle body cleaner, and spray that **** inside and go crazy, It will help out the idle a lot, if you do this. If you want to be **** about it, take the intake manifold and clean that too, the car will idle like new.
Old May 7, 2004 | 09:58 AM
Default Re: engine starts revving (spoonbenny)
thanks y0
Old May 7, 2004 | 10:10 AM
sohcvtec1995's Avatar
check your belts. my friend had the same problem but his idel would not go down. He took the ac belt off and now it idels normal.
Old May 7, 2004 | 10:58 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonbenny &raquo;</TD></TR><TR><TD CLASS="quote">Take that bitch, out and get some throttle body cleaner, and spray that **** inside and go crazy, It will help out the idle a lot, if you do this. If you want to be **** about it, take the intake manifold and clean that too, the car will idle like new.</TD></TR></TABLE>
Don't spray alot of cleaner into your intake manifold.
Spray the cleaner on a type of swab or cloth and wipe around.
Spraying to much into the intake manifold will result in check engine lights and your car not wanting to start until some of the cleaner evaporates.
Be careful and let us know
Old May 7, 2004 | 12:26 PM
civboy115's Avatar
Default Re: engine starts revving (Usdmdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by otakueric &raquo;</TD></TR><TR><TD CLASS="quote">how do you clean the tb?</TD></TR></TABLE>
should be 4 nuts holding it on...take them off, unhook your intake tubing and undo your throttle cable...pull it off and use brake cleaner or some sort of highpower degreaser or something and wipe all that shiizzz down and slap it back on.
Old May 8, 2004 | 11:31 PM
otakueric's Avatar
Default Re: engine starts revving (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">check your belts. my friend had the same problem but his idel would not go down. He took the ac belt off and now it idels normal.</TD></TR></TABLE>
why would the ac belt make a difference?
crxnonvtec
22
Sep 3, 2009 02:52 PM
drmix
Apr 2, 2008 05:33 PM
91 ef hatchback
Jun 9, 2007 11:26 AM
jdmCivic925
Oct 25, 2005 02:37 PM
wolf3007
Mar 26, 2004 05:06 AM
