How to get hood open? Hood latch broken!
Old May 6, 2004 | 05:31 AM
92BlackSi's Avatar
Default How to get hood open? Hood latch broken! NEED HELP ASAP!!
So a couple of weeks back I found out that my hood latch cable was stretched so I had to cut it halfway and manually pull the cable to open the hood. Now the cable is all fugged up and not working and the hood is shut. Is there a way for me to get the hood open without the use of the cable at all???
Modified by 92BlackSi at 2:01 PM 5/11/2004
Old May 6, 2004 | 06:42 AM
zman's Avatar
Default Re: How to get hood open? Hood latch broken! (92BlackSi)
Just get up under ur hood with a screwdriver and push the latch open with the screwdriver. It kinda takes a bit of patience, but once u do it once u'll be able to do it again no problem. I used to have to do it to Saturn Ions all the time cause their hood latch cables broke when it got cold outside.
Old May 6, 2004 | 06:55 AM
Andres-eh2's Avatar
correct!
Old May 6, 2004 | 07:00 AM
Yeung's Avatar
Default Re: (Andres-eh2)
yep screwdriver.. thats how some theives get under the hood..
Old May 6, 2004 | 07:41 AM
hatchdrvr's Avatar
Default Re: (Yeung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yeung &raquo;</TD></TR><TR><TD CLASS="quote">yep screwdriver.. thats how some theives get under the hood..</TD></TR></TABLE>
What? no crowbar? sawzall? C4?
Just park it in a bad area of town overnight, I guarantee someone will help you open your hood.
Old May 7, 2004 | 05:42 AM
92BlackSi's Avatar
Default Re: How to get hood open? Hood latch broken! (zman)
Cool thanks boys will try that out!
Old May 11, 2004 | 09:59 AM
92BlackSi's Avatar
K guys I just dived under the car to check out the screwdriver idea. Two things:
1. Where exactly are you putting the screwdriver? The only access to the latch area is through the bumper grill. I can just barely get my hand through the grill but once in no further.
2. You can't see the hood latch, so even if I got in there somehow where would I put the screwdriver??
I need some MAJOR HELP HERE! I don't want to have to do something sick to the hood!!
Old May 23, 2004 | 08:53 PM
akaEsCo01's Avatar
bump, i am having the same exact problem
Old May 23, 2004 | 09:32 PM
jigjew's Avatar
Default Re: (akaEsCo01)
just follow your hood latch cable and you'll see the "hook" that it is connected to on the latch. Then place the screwdriver in such a way that you will move it the same direction as the cable normally would. Bingo!
Old May 23, 2004 | 09:40 PM
JDMlyfestyle's Avatar
i love my 22" pry bar. it gets any thing open. thats y i call it the key to the city
Old May 24, 2004 | 10:48 AM
92BlackSi's Avatar
Default Re: (jigjew)
Yeah I got her I needed to remove all the plastic peices underneath to see the latch.
Old May 24, 2004 | 08:22 PM
akaEsCo01's Avatar
Default Re: (92BlackSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I got her I needed to remove all the plastic peices underneath to see the latch.</TD></TR></TABLE>
how did you do it??? i still can't get mine and i cut out my grill too, i have a 97 civic, but i don't think it is any different from a 93...or is it???
Old May 24, 2004 | 09:21 PM
4door_gsr_ftw's Avatar
Default Re: (hatchdrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchdrvr &raquo;</TD></TR><TR><TD CLASS="quote">
Just park it in a bad area of town overnight, I guarantee someone will help you open your hood.</TD></TR></TABLE>
The number one way for the lazy people...
Old Oct 15, 2004 | 09:52 PM
8point6's Avatar
Default Re: (Pacman88)
Another easy way to open the hood, assuming the cable is in its stock location, would be to remove the top of the fender liner, reach between the liner and the fender, grab the cable and yank it toward the rear of the car.
Old Oct 16, 2004 | 06:53 PM
billyhoe's Avatar
Default Re: (8point6)
on my civic i just reach throught the middle of the bumper a lil more towards the passenger side and feel for the cable (thin hard line) then just give it a yank to the left
Old Oct 16, 2004 | 11:11 PM
str8cyko's Avatar
if the cable is completely unattached from the latching mechanism, it would be useless to pull the cable. the screwdriver/crowbar would be the tool to use along with a jack.
tuan
Old Jul 16, 2016 | 03:06 PM
Aryez123's Avatar
K so i have an 04 honda civic and the cable broke off there is no cable at all so what now HELP
Old Jul 16, 2016 | 04:40 PM
eghatch9295's Avatar
Stancetard Hate Monger
old thread is old. forum choice is wrong. go away.
Old Jul 19, 2016 | 05:38 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Correct forum is for 7th Gen Civics.
Ancient thread closed.
haggecha
Honda Civic (2006 - 2015)
Jan 11, 2019 04:23 AM
FritschDog
22
Mar 31, 2017 08:41 AM
Slingah
Oct 4, 2012 09:41 AM
EL Vap133
41
Mar 31, 2004 02:08 PM
