B18c1 sol TPS help.
Old May 6, 2004 | 03:13 AM
imlachg1's Avatar
Default B18c1 sol TPS help.
Heres the deal, I while ago I was throwing a cel P0122 Throttle Position (TP) Sensor Circuit Low Input. I then assumed that I needed to replace the tps,, I checked the old TPS and could only get like .02 on my OHM meter. Then I replaced it thinking that would fix it. I put it on yesterday and it still doesn’t hit .5 it only hits .02 still. Whats the deal? I then talked to a gentleman that had the same problem that I did. He said he had to replace his ecu. I then replaced my ecu with a obd1 p72. I bought one and a jumper harness and replaced the old OBD2a ecu. Hoping that would fix the problem. I still can only get .02 out of it? Any ideas? And help would be great.
Old May 6, 2004 | 05:00 AM
monicle's Avatar
Default Re: B18c1 sol TPS help. (imlachg1)
you actually can "clock" the tps in order to get a correct reading. I would loosen up those screws and turn it a bit and see what you get whit the ohm meter.
Old May 6, 2004 | 05:26 AM
imlachg1's Avatar
Default Re: B18c1 sol TPS help. (monicle)
i did, i could only get .02? Thats at its max position. I even took it off and held the little trigger to wot, and could only get .07 or .08. Thats my problem. I can' figure out whats going on.
Old May 6, 2004 | 05:42 AM
monicle's Avatar
ah yeah that sucks then. Well see if you could borrow someones ecu real quick to test it.
Old May 6, 2004 | 05:47 AM
imlachg1's Avatar
I just replaced my ecu yesterday, with an OBD1 p72, and it still is doing it.
Old May 6, 2004 | 07:27 AM
imlachg1's Avatar
bump
Old May 6, 2004 | 09:57 AM
imlachg1's Avatar
Someone please help me out, anyone in the Pitts PA area wanna give me a hand. Any info on how to fix this would be usefull. Thanks.
LambertZ6
Jan 20, 2018 07:20 PM
Ruben19
Engine Management and Tuning
Sep 1, 2011 11:08 AM
whokid_911
May 26, 2009 03:04 PM
Catman316
Mar 21, 2005 07:51 PM
