skunk2 short shifter problem
I recently installed a skunk2 short shifter in my ek and now it won't enter into the gear easily. I have to force it in.
im sure it's happend to someone...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 »</TD></TR><TR><TD CLASS="quote">did u put it on bad words i have that shifter it is the best every other one breaks chekc if u installed it right</TD></TR></TABLE>
if the bend should lean towards the back of the car, then it's on right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedfreek128 »</TD></TR><TR><TD CLASS="quote">you might just need to loosen the bolt/nut that holds it on to the shift rod</TD></TR></TABLE>
i did tighten it too much but then loosened it up right to where both sides of the screw barelly touch.
ill3galdr1v3r
18
Oct 12, 2005 08:44 PM
