Where to locate the secondary O2 bung?
My friend has a 2001 Type R. He bought a JDM header and a JDM ITR cat
Problem: There is no hole for the secondary O2 in the cat.
Question: Does it matter where the hole is drilled in the cat for the new O2 bung?Will different drilling locations give different O2 readings?
Any help will be great.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 »</TD></TR><TR><TD CLASS="quote">My friend has a 2001 type r and bought a jdm header, and also bought a jdm itr cat
problem: there is no hole for the secondary o2 in the cat.
question:does it matter where the hole is drilled in the cat for the new o2 bunge?
*will different drilling locations give different o2 readings?
any help will be great.
thanks
What exhaust is he running? The JDM ITR cat won't bolt up to the stock exhaust...it's shorter than USDM cat by a fair amount...
and yeah...what RJ said...
thanks
</TD></TR></TABLE>What exhaust is he running? The JDM ITR cat won't bolt up to the stock exhaust...it's shorter than USDM cat by a fair amount...
i have a jdm cat for the jdm header. u would have to extend the piping on the cat to fit the usdm exhaust. they make a secondary o2 sensor bung for me and it works fine..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">
and yeah...what RJ said...</TD></TR></TABLE>
no its a ex mag II and it came with the extension peice, and he has a jdm header also. so basically u cant just drill a hole for the bunge???
or did you not read it correctly. cuz i did say a hole for the bunge.
-deven
-deven
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">The proper location is behind the cat.... you cant just drill a hole, you have to weld a sensor bung.</TD></TR></TABLE>
Actually, you have to do BOTH!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 »</TD></TR><TR><TD CLASS="quote">or did you not read it correctly. cuz i did say a hole for the bunge.
-deven</TD></TR></TABLE>
Just make sure the second O2 is after the catalyst.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 »</TD></TR><TR><TD CLASS="quote">or did you not read it correctly. cuz i did say a hole for the bunge.</TD></TR></TABLE>
No I read it correctly.
You can just drill a hole if you want..... but you'll have an exhaust leak and your o2 sensor wont stay in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">
thank you sir.
</TD></TR></TABLE>thank you sir.
