Fujitsubo Exhaust...
Old May 5, 2004 | 08:47 PM
HONDACURA-DB8's Avatar
Default Fujitsubo Exhaust...
I've been hearing that the fujitsubo exhaust is a good exhaust for the integra. My question is do they make one for a 4DR DC2 and where can I find this exhaust to purchase for a good price? What model? Thanx folks....
Old May 5, 2004 | 09:06 PM
Mikizzle's Avatar
4dr are DB8 not DC2. all you need to is get custom piping if they dont have one for you
Old May 5, 2004 | 09:09 PM
daewonder.'s Avatar
Default Re: Fujitsubo Exhaust... (4DR-DC2)
DC2 = GS-R or ITR coupe
if you have a DB8 or GS-R sedan, yes, they make one. The Legalis R can be had for around $750 i believe. Check out passwordjdm.com or talk to Tweakmeister on this board.
Old May 5, 2004 | 09:11 PM
PIC Performance's Avatar
The RM-01a will fit a 4dr just fine.
Old May 5, 2004 | 09:29 PM
Kendall's Avatar
It isn't like you can't easily modify one to fit anyways.
Old May 5, 2004 | 11:02 PM
WhoisDan's Avatar
jdm exhaust.
Old May 6, 2004 | 03:30 AM
ebelp's Avatar
Default Re: (whoisdan)
Ask Tweakmeister, or go to http://www.hogens.com.
Old May 6, 2004 | 07:22 AM
Dan GSR's Avatar
Default Re: (ebelp)
i would guess one for a 4dr ITR would fit nicely
Old May 6, 2004 | 01:26 PM
db8sirg's Avatar
dont know about the other lines but they only make the rm-01a for the dc2 (2dr).
but everyone should know that the only diff from a 2 and 4 dr teg is the muffer (same b-pipe length).
i have the rm-01a on my db8 and it works fine but it does come up short to the rear bumper.
but i like the way it looks.
heres a link to my review
of the exhaust and a video
too.
btw LEO @ passwordjdm (who i got it from) and Tweakmeister @ hogen should be able to get the Fujitsubo line of products.
Modified by db8sirg at 5:51 PM 5/6/2004
Old May 6, 2004 | 03:19 PM
Default Re: Fujitsubo Exhaust... (db8sirg)
Yup, same here. But in a way its nicer, because it doesn't portrude out too much, and is relatively sleeper.
Old May 6, 2004 | 05:26 PM
IntEGNYC's Avatar
notice how it burned away part of the bumper cover...
the exhaust pipe is also too far under the bumper. expect to get carbon monoxide poisoning
Old May 6, 2004 | 06:55 PM
db8sirg's Avatar
Default Re: Fujitsubo Exhaust... (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">notice how it burned away part of the bumper cover...
if you say so.
Old May 6, 2004 | 07:06 PM
RP215.'s Avatar
looks like heat wrap to protect the bumper to me
Old May 6, 2004 | 07:50 PM
No's Avatar
No
Default Re: Fujitsubo Exhaust... (chopstick407)
its great.My friend has it on his type R.Mega JDM hehe
Old May 9, 2004 | 09:05 PM
vtectag's Avatar
db8sirg, which model of car-sound cat are u using? is the welded cat end piece come from the stock cat? i'm getting the power getter..
any comment(s)?
Old May 10, 2004 | 04:44 AM
db8sirg's Avatar
Default Re: (vtectag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtectag &raquo;</TD></TR><TR><TD CLASS="quote">db8sirg, which model of car-sound cat are u using? is the welded cat end piece come from the stock cat? i'm getting the power getter..
any comment(s)?
i got the Stainless Round body 2.5 cat.
http://www.heeltoeauto.com/mar...sound/
i used the 2.5 flange off a used jdm itr cat. but the flange can be bought for 25-30.
Old May 10, 2004 | 09:03 AM
IntEGNYC's Avatar
why should anyone need heat wrap on their bumper?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chopstick407 &raquo;</TD></TR><TR><TD CLASS="quote">
looks like heat wrap to protect the bumper to me</TD></TR></TABLE>
Old May 10, 2004 | 10:36 AM
integranator's Avatar
Maybe the tip gets too hot, and he's worried about melting the bumper. I've seen it happen a couple times.
Old May 10, 2004 | 05:45 PM
vtectag's Avatar
db8sirg, your header have a 2.5 collector right?
so, how do you connect your 2.5" cat to the 60mm (2.36) cat back?
Old May 10, 2004 | 07:28 PM
db8sirg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">why should anyone need heat wrap on their bumper?
cause iam using a 2dr exhaust on a 4dr.
Old May 11, 2004 | 12:31 AM
Default Re: (grn4drgsr)
Thanks for the correction...
Old May 11, 2004 | 12:42 PM
96dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtectag &raquo;</TD></TR><TR><TD CLASS="quote">db8sirg, your header have a 2.5 collector right?
so, how do you connect your 2.5" cat to the 60mm (2.36) cat back?</TD></TR></TABLE>
The flanges that connect them have the same bolt pattern. You don't worry about tubing diameter at this part. Although if the tubing sizes differ a lot, say 2.5"--&gt;2", the bolt patterns are usually different.
NAmodified
Nov 11, 2007 06:05 PM
93(Civic)EG6
Sep 1, 2007 03:51 PM
dynamikz
Jun 20, 2005 05:32 PM
TypeR864
Sep 5, 2004 03:52 PM
