oil feed line
Old May 5, 2004 | 06:30 PM
zbower7's Avatar
Default oil feed line
where can u tap into the block for a oil feed line. can u do this where the oil pressure unit is. please tell me thanx
Old May 5, 2004 | 06:36 PM
SuzukaBlueAP2's Avatar
Default Re: oil feed line (zbower7)
yes. you need a brass "T" fitting if you want to retain your stock sensor. It's on the back of the block just above and to the left of the oil filter.
Old May 14, 2004 | 01:42 PM
cheapturbolines.com's Avatar
You can run one of these from the back of the block to a brass "T" fitting. This converts the BPT threads in the back of your block to the NPT threading in the brass "T" fitting. Then hook up your oil pressure sensor and oil feed line into the the brass "T" fitting.
or
You can run a sandwich adapter like this one between the block and oil filter and hook your oil feed line into this.
chris G.
96ej8MR
Sep 11, 2007 01:46 PM
95whitegizzer
Jul 12, 2006 11:59 AM
planoguy36
Apr 9, 2006 08:09 PM
jerbear!
Feb 9, 2005 12:30 PM
integranator
Apr 24, 2003 09:42 PM
