B20 head Vs a Ls head
Old May 5, 2004 | 06:00 PM
J-Spec EG's Avatar
Default B20 head Vs a Ls head
my friend is tryin to tell me that he thinks a ls head on a b20 would be better yhen a crv head on a b20. He said something about the Ls head flowing better what do you think?
Old May 5, 2004 | 06:36 PM
cliff666's Avatar
Default Re: B20 head Vs a Ls head (J-Spec EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Spec EG &raquo;</TD></TR><TR><TD CLASS="quote">my friend is tryin to tell me that he thinks a ls head on a b20 would be better yhen a crv head on a b20. He said something about the Ls head flowing better what do you think?</TD></TR></TABLE>
nothign is different from what i know between b20s and ls heads but the B20 cams i hear are slightly better than teh ls cams
Old May 5, 2004 | 08:00 PM
Sliced Beard's Avatar
Default Re: B20 head Vs a Ls head (bruceHungLO)
LS heads and B20 heads are <FONT SIZE="2">IDENTICAL</FONT>
Old May 7, 2004 | 01:44 AM
StorminMatt's Avatar
Default Re: B20 head Vs a Ls head (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">LS heads and B20 heads are <FONT SIZE="2">IDENTICAL</FONT></TD></TR></TABLE>
Yes, but only if the LS head is a 1994+. The 1990-1993 LS heads are not as good as either the 1994+ heads or the B20 head due to their smaller intake ports.
Old May 7, 2004 | 02:06 AM
Default Re: B20 head Vs a Ls head (StorminMatt)
they have the same casting why would they have a smaller intake port
Old May 7, 2004 | 02:51 AM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">they have the same casting why would they have a smaller intake port</TD></TR></TABLE>
Old May 7, 2004 | 04:03 AM
Joseph Davis's Avatar
Default Re: B20 head Vs a Ls head (non-VTEC)
I think Rocket, of Rocket Motorsports, and I argued this out once on his m24 forums.
The bump from 130 hp B18A1 to 140hp B18A1 was most probably where you got the bigger port PR4 head. So, 92+ heads. I know I've dealt with big port B18A1's... I have a '93 B18A1 that is a big port head.
Old May 7, 2004 | 07:09 AM
Default Re: B20 head Vs a Ls head (J. Davis)
the jump in hp was a result of timing and fuel maps along with a change in the exhaust and intake manifolds. i know for a fact that they are the same because i have THREE spare LS heads siting around and i MEASURED each one and found that they are all identical i have one from a 91 integra, a 94 integra and a 98 integra. all three of the castings are identical
Old May 7, 2004 | 07:35 AM
mmuller's Avatar
Mad Scientist
im not sure about the intake head ports, but i know there is a huge difference on the IM.
somebody elses pic:
also cams,EX man., ecu
Old May 7, 2004 | 08:45 PM
Default Re: B20 head Vs a Ls head (mmuller)
like i said before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">the jump in hp was a result of timing and fuel maps along with a change in the exhaust and intake manifolds. </TD></TR></TABLE>
Old May 7, 2004 | 09:32 PM
slomofo's Avatar
GDD Member
PR3 B16A/B, B18C5 have same castings don't they? But they're different.
Old May 7, 2004 | 09:38 PM
Default Re: B20 head Vs a Ls head (slomofo)
ok man you think that
low&slowef
Mar 5, 2011 03:02 PM
E_F_9
10
Feb 12, 2006 07:32 PM
SCIVIC94
Mar 3, 2005 06:57 PM
bryanb2
Jan 18, 2005 07:39 PM
