clevite engine bearings
Old May 5, 2004 | 01:59 PM
HondaGuy02's Avatar
Banned
Default clevite engine bearings
I called the local machine shop to find out what kind of engine bearings they use, they said they use clevite engine bearings.
Anyone know anything about clevite engine bearings? anyone have any experience with them? Just curious to hear some thoughts about em...
Old May 5, 2004 | 02:33 PM
VtecDeMoN's Avatar
Default Re: clevite engine bearings (HondaGuy02)
Hmm... never heard of them sorry I couldn't be more help. Personally I just stick to OEM.
Brian
Old May 5, 2004 | 02:42 PM
HondaGuy02's Avatar
Banned
Default Re: clevite engine bearings (VtecDeMoN)
me either but supposidly its what nascar uses
Old May 5, 2004 | 02:54 PM
RyanEJ8's Avatar
I've heard of them, but haven't really seen anyone with a Honda using them. I like the ACL's personally.
Old May 5, 2004 | 10:28 PM
LudeyKrus's Avatar
Clevites are mostly made for and used in Chevy's and Ford's. They don't make bearings for imports, I believe.
Old May 5, 2004 | 10:46 PM
H_doubledeuce_A1's Avatar
Default Re: (LudeyKrus)
Yep, clevites are mostly for Domestic cars I seen a lot of my domestic guys commin in Kragen and ask for them a lot. Clevite is starting to make import parts but not in big quanities however. I believe they started to make OEM style oil pumps and bearings for Hondas now but not quite sure. Have to check my computer.
Old May 6, 2004 | 04:33 PM
12thstreetjunkman's Avatar
Default Re: (H_doubledeuce_A1)
Clevite bearings a pretty good bearings, many many v8 people have used them for years, and they come with a lot of rebuild kits for all types of engines, I am not sure if they come in a 1 size fits all, or like oem, I have always used acl's with no complaints. Clevite may actually have something to do with acl, because acl bearings come with clevite lube, and the packages for clevite and acl both look the same.
Old May 6, 2004 | 04:38 PM
doublejz's Avatar
Default Re: (12thstreetjunkman)
i would say stick with oem or acl
Old May 6, 2004 | 05:14 PM
mmuller's Avatar
Mad Scientist
Default Re: (doublejz)
yeah, clevite makes bearings for hondas, check to see if they are the try-metal kind
Old May 6, 2004 | 05:35 PM
Kamin's Avatar
Default Re: (mmuller)
Clevite makes a well known domestic bearing. unforutionatley i dont know anything about how the import ones will hold up. the domestic ones are great.
i would say trust the clevites but if you dont want to, get ACL's or OEM if you must.
Old May 6, 2004 | 09:00 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
i know many people that use them with good results..400-500-600 hp hondas running them..with no probs at all..
Old May 6, 2004 | 10:37 PM
Super_Eg6's Avatar
my friend uses them and says they're good...from what he has heard on his DSM forums...
Old May 7, 2004 | 03:59 AM
Joseph Davis's Avatar
Default Re: clevite engine bearings (bruceleeroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">i know many people that use them with good results..400-500-600 hp hondas running them..with no probs at all..</TD></TR></TABLE>
What this guy said.
Clevite 77's are the tri-metal ones. You can order the damn things from Advance... $12 for a set of D-series rod bearings.
I wouldn't be surprised that Clevite makes ACLs, as suggested above, just like Daikin (Exedy) makes Honda clutches or Fram makes Honda oil filters, etc. I'd try to find out for sure before I started repeating it, mind, but I wouldn't be surprised at all.
Old May 7, 2004 | 07:00 AM
mmuller's Avatar
Mad Scientist
Default Re: clevite engine bearings (J. Davis)
Acl's are made in Australia
Old May 7, 2004 | 01:31 PM
AzG35's Avatar
Default Re: clevite engine bearings (mmuller)
I had clevites in my old motor. They worked fine and I didn't have any problems with them. 35,000 miles and they looked good when I pulled them out.
Old May 7, 2004 | 03:24 PM
spaceman's Avatar
Default Re: clevite engine bearings (AzSi22)
what other companies make good bearings?...i seen some bearings at powerenterpriseusa.net not sure if they make honda bearings tho
Old May 14, 2004 | 10:41 AM
-Trinitron-'s Avatar
Clevite makes OEM honda bearings...according to a customer of mine that is a rep for Clevite ACL is Crap. I am pretty sure that if you asked a rep for ACL they might reply the opposite though.
Old May 14, 2004 | 10:46 AM
wickedEFguy's Avatar
Default Re: (-TRINiTRON-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- &raquo;</TD></TR><TR><TD CLASS="quote">Clevite makes OEM honda bearings...according to a customer of mine that is a rep for Clevite ACL is Crap.</TD></TR></TABLE>
huh?????
ACL is crap?? But then again Clevite makes OEM bearings and there good?
I think the reason that rep says that is he probably drives a mullet
Old May 14, 2004 | 10:48 AM
Default Re: (wickedEFguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy &raquo;</TD></TR><TR><TD CLASS="quote">
I think the reason that rep says that is he probably drives a mullet</TD></TR></TABLE>
Haha...he might, I have actually never met him. He is down in Florida.
I actually found this post to see if everyone preferred OEM or ACLs just for that reason. Of course a rep is gonna tell me his competition is crap. From what I have read though it does seem that OEM bearings are preferred. If Clevite does infact make them...then I guess that answers my question. Anybody else got any input?
Old May 14, 2004 | 10:54 AM
here goes the OEM vs. ACL bearings thread again
Mostly a ACL bearing is a lot harder then OEM. I'm using ACL because I'm 83mm in my B16 or I would use OEM. Honda knew what they were doing from the get go
Old May 14, 2004 | 10:56 AM
Too_Smooth's Avatar
Yeah like someone else said Clevite makes bearings for hondas. I had a set in my last Ls/Vtec. I put about 40k miles on them while I had the motor. I sold it to a friend and it's still going without any problems. Oh and they're tri-metal just like OEM bearings.
Old May 14, 2004 | 10:58 AM
Default Re: (Too_Smooth)
How about this guys
OEM =
ACL = (If your outta spec)
Old May 14, 2004 | 11:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy &raquo;</TD></TR><TR><TD CLASS="quote">How about this guys
OEM =
ACL = (If your outta spec)</TD></TR></TABLE>
Sounds good to me!
PS &lt;---102K on OEM bearings and still going strong.
Old May 14, 2004 | 04:13 PM
Rocket's Avatar
Clevite is good but sometimes they don't get the tangs right on the main bearings.
ACL's are a lil less expensive but are one hell of a bearing, so if you are not using OE, ACL's make the most since.
I've been selling ACL's for about 2.5 years and it's the most reliable product I sell with the least complaints of all products I have sold.
Here are the list of bearing brands.
- OE
- ACL
- Clevite
- Federal Mogul
- King
- Made in ROC (republic of China)
Take your pick.
Old May 16, 2004 | 12:43 PM
Super_Eg6's Avatar
im going to rebuild my lsv and my friend that is supplies my parts says he can get Federal Mogul for dirt cheap. Should i use them or stick to the OEM honda ones?
