ITR throttle body v. GSR throttle body?
Old May 5, 2004 | 01:38 PM
EMO-anthony's Avatar
Default ITR throttle body v. GSR throttle body?
Im debating if I should buy a ITR throttle body? Does anyone know if I would have any significant gains from using a ITR throttle body rather than my stock GS-R throttle body? I plan on putting this on my Skunk 2 IM. Thanks
Old May 5, 2004 | 02:00 PM
jDMJeRk's Avatar
Default Re: ITR throttle body v. GSR throttle body? (THAiGuYDc2)
Id just bore match your gsr throttle body to the skunk manifold. thast the cheapeset most cost efficiant (sp) and more power gain for the money
Old May 5, 2004 | 04:15 PM
94gsr4dr's Avatar
Default Re: ITR throttle body v. GSR throttle body? (jdmjerk)
if you can find a cheap itr or ctr tb then get it or else send your tb out to king motorsports, i think it is 150 or so for boring to 64mm.
Old May 5, 2004 | 07:59 PM
jDMJeRk's Avatar
Default Re: ITR throttle body v. GSR throttle body? (94gsr4dr)
there is a guy on honda-tech thatll rebuild your throttle body for 100 bucks
2-3 day turnaround and that includes shipping it back and the bore job
Old May 5, 2004 | 08:17 PM
zilverz's Avatar
The port on the Skunk 2 is 65mm
our throttle bodies can only be bored 4mm over. This is the route i suggest. GSR is 60mm so the closest you can get it is 64mm with it ... which is perfectly fine. Just for the other guy saying to port match it is 1mm shy
Im running a Bored LS TB on my SKunk 2 its only 62mm but definately better than 58mm (:
Old May 5, 2004 | 08:22 PM
gundamgsr's Avatar
your best bet ,imo, is to get a jg 65mm t/b with your 65.2mm skunk2 i/m. thats what i got.
Old May 5, 2004 | 08:59 PM
riceball777's Avatar
Default Re: ITR throttle body v. GSR throttle body? (zilverz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zilverz &raquo;</TD></TR><TR><TD CLASS="quote">
Im running a Bored LS TB on my SKunk 2 its only 62mm but definately better than 58mm (:</TD></TR></TABLE>
wrong
itr im is 62mm sjunk2 is 64mm and aebs im is 65mm
and gsr tb is 58mm and can be bored to 62mm
Old May 5, 2004 | 10:41 PM
Default Re: ITR throttle body v. GSR throttle body? (riceball777)
but would i see any significant gains if i do get the ITR TB?
Old May 6, 2004 | 06:29 AM
Xsi's Avatar
Xsi
No huge HP gains but expect a nice gain in throttle response
Old May 6, 2004 | 06:37 AM
msmithgsr2131's Avatar
Default Re: (Xsi)
This is the guy im sending my throttle body to. https://honda-tech.com/zerothread?id=771875
Old May 6, 2004 | 04:12 PM
zilverz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">
wrong
and gsr tb is 58mm and can be bored to 62mm</TD></TR></TABLE>
Wrong
I know ITR is 62mm never said otherwise ( I said my LS is bored over to 62mm)
GSR TB is 60mm
LS is 58mm
Skunk 2 port is 65mm
undagroundrican
Jan 12, 2005 06:50 PM
TimeRacer
Nov 17, 2002 08:19 AM
MXPX
Sep 1, 2001 08:48 AM
