2000 accord rotors
hi,
my friend needs a front brake job. can anyone tell me if the rotors are held by 2 screws similar to civic/integras or are the rotors behind the hub?
if they are held by the (2) screws then i can turn the rotors if not. it's gonna be a pain. lemme know thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bill-71SS »</TD></TR><TR><TD CLASS="quote">yes they are</TD></TR></TABLE>
yes they are held by screws or pressed in?
by the way its a 4cyl accord not the 6, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitelightning »</TD></TR><TR><TD CLASS="quote">
by the way its a 4cyl accord not the 6, thanks</TD></TR></TABLE>
they're held by 2 screws. lucky u!!!
Drag yer fingernail across the rotor, if you feel any snags, turn the rotors 'specially if the pads have gone to the metal. If the rotors still appear to be smooth and there is no pulsation in the brake pedal or steering wheel shake when braking, IMHO just drop a new set of pads in. I know some people are gonna disagree, but if you remove the rotors to get em resurfaced, it's likely they will warp. If you must resurface, yer best bet is to find a shop with an on car brake lathe. This will ensure that the rotor is machined perfectly true to the hub.
.BigSexy
Jun 19, 2007 02:42 PM
Nisif
Sep 11, 2006 04:45 PM
