can a bad intermediate shaft causing steering vibrations
Old May 5, 2004 | 10:50 AM
whitelightning's Avatar
Default can a bad intermediate shaft be the cause of steering vibrations
hi,
i've replaced my axles, i've got a grinding sound coming from (?)
i'm thinking it's my intermediate shaft, not sure how to determine it.
my steering wheel shakes as well, could this be the intermediate shaft?
Old May 5, 2004 | 11:02 AM
typeass's Avatar
Default Re: can a bad intermediate shaft be the cause of steering vibrations (whitelightning)
Bad rotors can cause steering vibrations under braking.
Old May 5, 2004 | 11:35 AM
Default Re: can a bad intermediate shaft be the cause of steering vibrations (typeass)
my rotors were just turned. new balanced tires put on as well.
anyone know how i can determine if the light rattle/grinding sound during acceleration is my intermediate shaft?
Old May 5, 2004 | 12:00 PM
TypeR 599's Avatar
Why do you think it's your intermediate shaft?
Are you sure you have the right axles? What kind are they, rebuilt?
Old May 5, 2004 | 12:08 PM
ericlee303's Avatar
Default Re: can a bad intermediate shaft be the cause of steering vibrations (TypeR 599)
I'm having the same problem with my DA teg. I think the outer left axle is out of spec. It's old and the boot is also ripped. I've replaced the rotors and wheels as well with no change in shaking. I doubt its the bearings either - they seldom cause shaking.
Old May 5, 2004 | 12:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 &raquo;</TD></TR><TR><TD CLASS="quote">Why do you think it's your intermediate shaft?
Are you sure you have the right axles? What kind are they, rebuilt?</TD></TR></TABLE>
i don't know what else it could be. i've replaced my left lower ball joint, my left wheel bearing, axles twice(autozone) and still have the grinding/rattle sound??
05foresterxt
Mar 24, 2011 01:27 PM
GibsonNO!
Jan 28, 2009 07:37 AM
DeDonDeRosa
Sep 6, 2006 11:25 PM
gurgle
Mar 21, 2006 05:57 AM
opiumdaze
Feb 13, 2006 09:50 PM
