b17 / p61 wiring pinouts
Old May 5, 2004 | 06:55 AM
moose1309's Avatar
Default b17 / p61 wiring pinouts
Apologies in advance if this is in the wrong section.
If there's anyone with a 92 gsr w/ stock wiring, can you check what color wires are going into your ecu wiring harness for vtec solenoid and vtm sensor?
Alternatively, does anyone have pinout diagram for p61 and also the colors of the wires coming from the engine.
Explanation: I just pulled out my vafc and lost track of vtec solenoid and vtm wire.
thanks!!!!!
Old May 6, 2004 | 12:49 PM
moose1309's Avatar
Default Clarification and bump?
Anyone who has the stock under-dash harness. -- please please -- help out a noob, God will reward you
Old May 7, 2004 | 07:39 AM
boomslang's Avatar
Default Re: b17 / p61 wiring pinouts (moose1309)
VTEC Solenoid --> Pin A4, Green with yellow stripe.
VTM --> Pin D6, Blue with black stripe.
Old May 7, 2004 | 08:28 AM
SwedBoy2999's Avatar
When i get home from school i'll take a pict and scan the page of the helms.
Old May 7, 2004 | 08:46 AM
moose1309's Avatar
Thanks both. You rock
Pic would be helpful; my car had an engine swap and various vtec controllers so the wires are all cut up and spliced; I'm not sure how the stock one looks.
I took a wild guess tho and car runs fine WOOHOO but check engine light comes on after 10 min of driving... maybe unrelated
Old May 12, 2004 | 06:38 AM
moose1309's Avatar
vtec isn't cutting over. my a4 and d6 pins are wired to the wrong things; that's my problem.
Old May 17, 2004 | 03:40 PM
moose1309's Avatar
here's a pic of me holding a4 and d6, and what they're going into.
If anyone can tell if this looks right... I'm still not getting vtec cutover. (tried switching them)
Old May 18, 2004 | 05:19 AM
moose1309's Avatar
woops never mind. my q just got answered ...
Old May 18, 2004 | 05:28 AM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moose1309 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
nice ghetto rigged...
using duct tape on electrical wiring.....
why not use heat shrink its only $3. at radio shack
and will save you the headache of a shor circuit....
Old May 18, 2004 | 07:31 AM
SpooN Man's Avatar
Default Re: b17 / p61 wiring pinouts (mr.beeks)
duct tape is a conductor that might be part of the problem.
saintbhts
Aug 2, 2014 10:08 AM
Brian Hinson
Sep 11, 2005 08:50 AM
teg2000
Nov 6, 2003 03:29 PM
JOHN WAYNE
Aug 23, 2002 09:59 PM
