DOHC ZC Timing, is it off??
Old May 5, 2004 | 06:33 AM
StupidSlowRSX's Avatar
Default DOHC ZC Timing, is it off??
When I stick a screwdriver down in cyl1, once its at the top of its compression stroke, the cam gears are aligned.. Does this mean the crank is too? Im throwing a code 4, and I just replaced my dizzy, I dont get it... As it is, the car will idle, and sound fine. but when i give it a little gas, it bogges horribly. Naturally, the car has no power..ideas?
Old May 5, 2004 | 06:52 AM
esoterEK..'s Avatar
Default Re: DOHC ZC Timing, is it off?? (StupidSlowCRX)
no it doesnt mean the crank is too. Align the Crank and see if the cam gears are align if not then it's off. Aligning the crank is the main thing becuase it's TDC if the crank is align.
Old May 5, 2004 | 06:55 AM
How do I align the crank? I know usually theres suppose to be a white line for timing, along with some red marks for ignition timing. But i dont have the white dot or any grooves, just the 2 red dots
Old May 10, 2004 | 04:52 PM
Akira54's Avatar
h23vtec_dc2
Mar 7, 2010 12:20 PM
4gencivicef9
Jun 14, 2007 06:27 PM
yz125rider21
Jan 10, 2006 09:04 PM
StupidSlowRSX
May 5, 2004 03:58 PM
EKB18BPR3
Dec 25, 2003 03:21 PM
