whats this sound coming from?
Old May 4, 2004 | 09:38 PM
auburnBoy's Avatar
Default whats this sound coming from?
my car has a new d16z6 i think...the japanese version. anyway, when i first turn my car on for about ten minutes or until it warms up my engine keeps reving up on its own...like a pulsating sound. does anyone know what the hell this is.
Old May 4, 2004 | 10:01 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: whats this sound coming from? (auburnBoy)
Its normal
Thermo Idle valve makes it idle higher so itll warm up
Old May 4, 2004 | 10:11 PM
auburnBoy's Avatar
Default Re: whats this sound coming from? (Vortech99Si)
yah but normal cars dont do that and it sounds hella gettho. can i fix it?
Old May 4, 2004 | 10:15 PM
crazy eyez killa
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by auburnBoy &raquo;</TD></TR><TR><TD CLASS="quote">yah but normal cars dont do that and it sounds hella gettho. can i fix it?</TD></TR></TABLE>
"normal" civics and integras do. All of them. You should hear a boosted one with solid mounts. Now that sounds ghetto...
Old May 4, 2004 | 10:22 PM
auburnBoy's Avatar
i dont think you know what i mean...itll be at 1x rpm then rev up to 2x or more and then back down and then up again...all in like a second. it sounds like im tapping the pedal constintly. i had a tech listen to it and he said that it has something to do with the thermostat and the coolent or something cause it stops once the engins warmed up. what do you think?
Old May 5, 2004 | 07:31 AM
crazy eyez killa
Guest
Posts: n/a
OK I have a 99 Civic w/ a B16A2. It idles around 2k when cold.... but smoothly, and drops below 1k when warm.
I know 2 friends, one with a modded D16Z6 95 EX, and one with a turbo 99 LS integra, both of theirs idle like they have cams when cold, like you said, 2k to 1k to 2k and back and forth until its warm. They consider it normal.
Ive seen some Hondas that do that and some that don't
Old May 5, 2004 | 08:07 AM
kur0ryu's Avatar
sounds like a vaccuum problem, a friend of mine had a first gen b16a that was doing that after the swap, but his vaccuum lines were set up wrong. check that maybe?
Old May 5, 2004 | 08:20 AM
limpmode's Avatar
Default Re: whats this sound coming from? (kur0ryu)
could be a vaccum problem like kur0ryu said, but i would also check the IAC, it could be bad or need to be cleaned. ive seen that be the cause of this b4 too
Old May 5, 2004 | 12:58 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vortech99Si &raquo;</TD></TR><TR><TD CLASS="quote">
Ahh yes.. Everytime I start my car.. Dont you just love it though..
Old May 5, 2004 | 01:08 PM
doublejz's Avatar
Default Re: whats this sound coming from? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Ahh yes.. Everytime I start my car.. Dont you just love it though.. </TD></TR></TABLE>
Naw, i love it more when u shift or take your foot off the gas. ssppttttt
Old May 5, 2004 | 01:22 PM
tgreaves's Avatar
Default Re: whats this sound coming from? (doublejz)
True.. True.. I love when you floor it from a light and the person your racing is right next to you and your just waiting for what you know is commin'..
Old May 5, 2004 | 01:44 PM
Rtype16's Avatar
I would either say your fast idle thermo valve is broken or the idle motor is clogged. They are not supposed to do that.
Rtzx9r
Honda S2000
May 18, 2007 10:22 PM
MaxBoost
32
Apr 18, 2005 11:22 AM
budget
Mar 3, 2005 06:57 AM
EF8_SiR
Sep 20, 2002 05:51 PM
Black Sheep
Apr 18, 2002 09:40 AM
