Cams and turbo?
I have the Crower 62404 cams in my 98 LS along with the springs and retainers from Crower. I wanted to get the DRAG GENII turbo kit. Would these cams be a benefit for the addition of the turbo, or would they actually hurt my performance with a turbo? Thanks everyone, Jason.
If I understand turbos right, you want lift on the cams, but not duration. Too much duration can bleed boost. Those Crowers may have a little too much duration. One way to find out, dyno with both...
Jason
Jason
Yeah, I think there will be too much overlap with upgraded cams. This is what I've heard from several people. You'll probably want to stick with stock cams. Since you have an LS, i'd double check. Most of the people that told me to stick with stock cams were referring to the GS-R.
