just got a type r radiator, and found out it was thinner then my ls radiator.
Old Nov 3, 2001 | 08:30 PM
confucius's Avatar
Default just got a type r radiator, and found out it was thinner then my ls radiator.
okay, why is my ls radiator about 1cm thicker then the type r radiator?
is it to save weight?
the type r radiator i bought is black. has denso stamped on it.
my ls radiator is kinda tan looking.
my friend ls radiator is black also.
what color is ur radiator?
Old Nov 4, 2001 | 05:07 AM
IN VTEC's Avatar
Default Re: just got a type r radiator, and found out it was thinner then my ls radiator. (confucius)
Yes
Old Nov 4, 2001 | 08:27 AM
Integra_Boi's Avatar
New User
black... lemme know how that type R radiator goes.. i mite get one for earlie maintenance
Old Nov 4, 2001 | 11:32 AM
Web_Head's Avatar
New User
Default Re: just got a type r radiator, and found out it was thinner then my ls radiator. (Integra_Boi)
I wouldn't waste the money on a type r radiator. I bought a new after market raidiator from a local shop and it only cost me $150. If you want a real mod to keep your engine cooler, why not add an oil cooler?
Old Nov 4, 2001 | 12:20 PM
Etylorcen's Avatar
Default Re: just got a type r radiator, and found out it was thinner then my ls radiator. (Trench)
Or get a fluidyne
Old Nov 4, 2001 | 06:22 PM
confucius's Avatar
well, i got it for 80 bucks, and its it pretty good condition. my ls was leaking.
Old Nov 4, 2001 | 08:02 PM
Web_Head's Avatar
New User
Cool, I thought you bought it new from a dealer.
Old Nov 5, 2001 | 05:17 AM
b18b98's Avatar
Default Re: just got a type r radiator, and found out it was thinner then my ls radiator. (cotton_lix)
what year is your LS?? My radiator is the same exact one as my friend's type R..with denso stamped on it. Mine is a 98 RS and his is a 2000 type R and nothing is different.
Old Nov 5, 2001 | 08:48 AM
Duck Sauce's Avatar
Default Re: just got a type r radiator, and found out it was thinner then my ls radiator. (b18b98)
Reason why RS's and ITR's have the same radiator is because they both don't have A/C. GSR's, and LS's have the same radiator unit.
Old Nov 5, 2001 | 09:32 AM
B2FiNiTY's Avatar
Won't exactly keep your car "cooler" but it will keep the car's tempeture more stable. It will keep it "cooler" if you mean that your engine gets very hot and it will keep the temps near normal. HTH
Old Nov 5, 2001 | 09:42 AM
96IntegraLS4DR's Avatar
Or get a fluidyne
Will this keep your car cooler? How much?
If you want to run cooler try a lower temp thermostat.
Fluidyne will not give you leak at top and bottom plastic crimp b/c it doesn't
have plastic top nor bottom.
jumbronee
Nov 23, 2008 09:10 PM
GeoffMontgomery
Aug 28, 2005 07:01 PM
reno96teg
Aug 18, 2004 07:51 PM
x James Bond x
Apr 8, 2003 08:51 AM
confucius
Nov 2, 2001 04:29 PM
