downpipe bolts keep popping off on Drag 3 ....................any suggestion ???
Old Nov 3, 2001 | 07:24 PM
DIRep972's Avatar
Smarter than you
Default downpipe bolts keep popping off on Drag 3 ....................any suggestion ???
this is Flameco-T, I am using Direp972 comp..
my downpipe bolts from the drag kit, keep losing thread, I used Loctite red, it is kinda hard to tighten the bolts up, due to clearance, but, we did it as tight as possible and one out of five is coming loose, it exposed about two threads now...
any suggestion ? should I just get the damn things welded..
TIA
Old Nov 3, 2001 | 08:16 PM
Incognito's Avatar
Default Re: downpipe bolts keep popping off on Drag 3 ....................any suggestion ??? (DIRep972)
Do U have a flex pipe in your downpipe? Try this; Weld in a flex pipe, about 5" in length minimum, right before the cat (or test pipe), and use lock washers for the downpipe to turbo and turbo to manifold bolts. This should work. Worked for me when I had the Drag kit.
Old Nov 3, 2001 | 08:56 PM
RTEK's Avatar
New User
Default Re: downpipe bolts keep popping off on Drag 3 ....................any suggestion ??? (Incognito)
he's absolutely correct!
you also need to know that the heat generated by the turbine will burn any locking adhesive made by man
besides the flex pipe or OEM donut type gasket and cup flange, you also need to go to the hardware store and buy lock washers if you don't have it already. this will cost you less than $1.00
hope this helps
Old Nov 3, 2001 | 10:07 PM
LsTurbo91's Avatar
I use studs on there now with lock washers, problem solved.
Old Nov 4, 2001 | 09:13 AM
Turbo00's Avatar
New User
Default Re: downpipe bolts keep popping off on Drag 3 ....................any suggestion ??? (LsTurbo91)
and try using anti-seize i dont think loc tite can hold up to those temps
95whitegizzer
Jun 20, 2006 11:27 AM
riceburnah
Jul 4, 2005 09:15 PM
TheOne
Jan 11, 2004 09:12 AM
B18EG6
Apr 7, 2003 12:18 AM
R-1303
Dec 16, 2002 04:26 PM
