Installed new dashboard (NO BLINKERS! =/)
Old May 4, 2004 | 03:38 PM
Ditdogs's Avatar
Default Installed new dashboard (NO BLINKERS! =/)
okie so i installed a new gsr dashboard into my dc2 94 Integra, everything is working fine but i cant get my left and right blinkers to work, i checked the fuse and it is good, checked the relays they are good. i have no idea what is up, my hazards work fine, when i put the left or right signal down or up, it doesn’t even light up on the cluster... im guessing it is a wiring problem, but the harness that was on the dashboard was basically plug and play... i have no idea what is wrong,
Does anyone have any idea what is wrong? or have a layout of a dc2 dashboard wire harnesses? i searched and i found nothing.
thnx in advance.
Old May 4, 2004 | 03:58 PM
cccccccc's Avatar
Default Re: Installed new dashboard (Ditdogs)
does the lever click in down or up
if you need a new switch assembly i have one
since they work with the hazards my guess would be the switch
Old May 4, 2004 | 04:31 PM
IntEGNYC's Avatar
Default Re: Installed new dashboard (c13r)
did you check the bulbs?
Old May 4, 2004 | 04:43 PM
Ditdogs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c13r &raquo;</TD></TR><TR><TD CLASS="quote">does the lever click in down or up
the lever clicks up and down like it should,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">did you check the bulbs?</TD></TR></TABLE>
my hazards work... bulbs are the same for the hazards/turn lights.
Old May 4, 2004 | 11:27 PM
Ditdogs's Avatar
bump
Old May 5, 2004 | 06:00 AM
frenchy's Avatar
since they work with the hazards my guess would be the switch</TD></TR></TABLE>
the switch is in the steeirng column though - the colum/wheel is the same right? - ill see if i can get a wiring diagram - your not cool with hand signalling or what
edit: the turn signal wiring is not in the dash harness
Modified by frenchy at 3:25 PM 5/5/2004
Old May 6, 2004 | 05:14 AM
Ditdogs's Avatar
Default Re: Installed new dashboard (frenchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frenchy &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by frenchy at 3:25 PM 5/5/2004</TD></TR></TABLE>
where is the turn signal wiring then? i thought it was one of the harnesses right under/next to the steering wheel.
Old May 6, 2004 | 09:40 AM
frenchy's Avatar
you said you put in a new dash and plugged everything in, but the turn signal wiring is not in the dash harness - basically the new dash/wiring shouldnt have anything to do w/ your turn signals not working
how did you check the relay?
Mleach
18
Jul 4, 2005 07:58 AM
ME=ADRIAN
May 26, 2005 05:59 PM
komat
Feb 26, 2005 02:56 PM
Ditdogs
Audio / Security / Video
May 4, 2004 11:27 PM
krazyDOHC
27
Aug 18, 2003 04:24 PM
