Am I losing power with my icebox?
Old May 4, 2004 | 03:08 PM
r0c5t4r's Avatar
Default Am I losing power with my icebox?
I installed my homemade icebox using a short ram intake and the stock intake box but it seems to me that I don't have as much of a response as when I had a cai installed. I used the same filter and half tube as the cai so what could be wrong? Or is this icebox restricting air flow?
Yeah I know my engine bay is hella dirty.
Old May 4, 2004 | 03:24 PM
projectTeG's Avatar
it could be restricting, but sri are suppose to help the response but where the coolsnt coming from thats on the box?
Old May 4, 2004 | 04:36 PM
IntEGNYC's Avatar
Default Re: Am I losing power with my icebox? (dfunkd)
are you putting a cone filter inside the box or do you have the piping sealed to the box and using the stock paper filter?
without knowing what your "homegrown" set up is, its hard to comment.
Old May 4, 2004 | 06:26 PM
timmy8151's Avatar
Default Re: Am I losing power with my icebox? (IntEGNYC)
Did you modify your stock box like BSQ's setup? If not, then what you're running isn't much better than the stock system.
Here's BSQ's page: http://www.geocities.com/bretq
Old May 4, 2004 | 11:13 PM
WhoisDan's Avatar
just take out the filter box, attach a cone filter.
Old May 4, 2004 | 11:49 PM
xplanetearth420x's Avatar
Default Re: (whoisdan)
take off the box make it a short ram
Old May 5, 2004 | 02:20 AM
IntEGNYC's Avatar
Default Re: (xplanetearth420x)
*crickets*
Old May 5, 2004 | 10:14 AM
95 integra's Avatar
Default Re: (IntEGNYC)
do you even have a complete seal around your airbox where the intake pipe goes into it?
Old May 5, 2004 | 10:16 AM
InfamousGSR's Avatar
Default Re: (95 integra)
bump. would like to know your home brew setup.
Old May 5, 2004 | 11:31 PM
r0c5t4r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">do you even have a complete seal around your airbox where the intake pipe goes into it?</TD></TR></TABLE>
I don't have a complete seal around it. And to ^ I will show you a DIY probably by tomorrow.
Old May 5, 2004 | 11:36 PM
Cramerox's Avatar
Default Re: (dfunkd)
sup with the coolant?
Old May 6, 2004 | 05:34 PM
IntEGNYC's Avatar
Default Re: (Cramerox)
mistreated teg...
put the stock intake arm back... youre only hurting the car and its performance sucking in unfiltered air.
Old May 6, 2004 | 06:07 PM
cougar10ag's Avatar
unless you ahve a tube going from the bototm of the box down to behind the turn signal then it's not an icebox. and of course you won't have the same response.. you are restricting air!! the comptech icebox is huge. it is the biggest possible size for each application to increase response. chuck the box. get a cone filter
Old May 6, 2004 | 06:09 PM
bub838's Avatar
weee butt dyno
Old May 6, 2004 | 07:33 PM
r0c5t4r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">mistreated teg...
put the stock intake arm back... youre only hurting the car and its performance sucking in unfiltered air.</TD></TR></TABLE>
The air is getting filtered using an injen air filter which inside the stock box, I wouldn't mistreat my teg. I love this car.
BTW Cougar, I do have a tube coming down behind the turn signal. Also the Comptech box is what, $400 or something like that? For that amount of money i'd go for the Mugen which is only $200 more. Mine costs me $40 which I thought would be good just for the time being.
Old May 6, 2004 | 07:43 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfunkd &raquo;</TD></TR><TR><TD CLASS="quote">
BTW Cougar, I do have a tube coming down behind the turn signal. Also the Comptech box is what, $400 or something like that? For that amount of money i'd go for the Mugen which is only $200 more. Mine costs me $40 which I thought would be good just for the time being. </TD></TR></TABLE>
So I guess you have a setup similar to the BSQ Icebox? BTW, the Comptech Icebox + filter only cost me about $220, not $400.
Old May 6, 2004 | 09:45 PM
sshaikh01's Avatar
i don't know about power, but i do know you lost come coolant there buddy
Old May 7, 2004 | 02:53 AM
IntEGNYC's Avatar
yadda yadda... why dont you take 5 seconds and clean up the coolant spray in your engine bay?
Old May 7, 2004 | 11:29 AM
cougar10ag's Avatar
ok i didn't know if you had the tub or not on the bottom...fact still remains. using the stock airbox will decrease response as it is small.
Old May 7, 2004 | 11:44 AM
G
sh!t happens.
Default Re: (cougar10ag)
puta turbo on it
ITRacer121
Oct 28, 2003 06:34 AM
Brett
Oct 27, 2002 09:07 AM
LillDragun
Sep 2, 2002 10:15 PM
Rdriven
Jul 1, 2002 08:27 AM
IGGY
Dec 27, 2001 10:27 PM
