Help Car wont start????
Help my car wont start!!! i checked all the fuses and everything checks out, when i try to start my car i can hear the starter clicking so its not that. i checked the ecu for codes and theres nothing but the check engine light is lit... any one have any clue to why my car wont start... btw its a 91 dx....
Have you checked your main relay to see if it is functioning? Maybe your ignitor died like so many others. Check to see if you are getting spark and/or fuel. HTH.
cyber13
cyber13
If your light stays on with no codes check the following- there is a fuse in the dash fuse box labeled solenoid- be sure it is there and good. Also, check the ground that is close to the thermostat housing- remove and clean it and reinstall. If this doesn't help, with the key on, remove your sensor wires one at a time, checking the light each time. If the light goes out- inspect the sensor that let it go out when the connector was removed.
LScivic_wpg
May 27, 2006 10:10 PM
No More Civic
10
Aug 27, 2002 09:35 AM
