ignition related?
Old May 4, 2004 | 01:22 PM
8200RPM's Avatar
local hippie
Default ignition related?
Im hoping to get some input from some of you guys on here, my car is driving pretty wierd lately and I thought I had fixed the problem...
96 d16y8 w/ ~180k miles.
car basically bogs anywhere between 1000-3500 RPMs. This isnt all the time, just every now and then but its been happening more frequently lately. The car was barely driveable a few months ago, sputtering really bad, so I changed the plugs, wires and distributor cap bc upon inspection of it- I noticed where cyl #2 plugs in it was corroded. This work fixed the problem.
(giving as much info that might be helpful to diagnose the problem)
When I drive the car, sometimes, lets say for example around 2500 rpms it feels & sounds like its stuck- you push the accelerator but it hesitates to keep driving smoothly. Other times its less noticeable and as you're driving it feels like the car "skipped a heart beat".
I know this shouldn't be too hard to figure out- just hoping someone could point me in the right direction.
Im thinking it must be ignition related, could it be fuel related?
CLIFF NOTES: car has a periodic sputter between 1000-3500 rpms.
TIA
Old May 4, 2004 | 03:21 PM
APEX CRX's Avatar
Default Re: ignition related? (8200RPM)
there are no cels at all when this happens?
Old May 4, 2004 | 10:51 PM
8200RPM's Avatar
local hippie
Default Re: ignition related? (APEX CRX)
nope, no cel's
i was forced to change my spark plugs today cause a friend threw my bosch's in the trash (he couldnt bear see my car with those)! doh... so yea ngks now. i also changed the fuel filter and attempted to change the rotor but discount gave me the wrong one. car is still sputtering. so i guess ill get the correct rotor, change that and see what happens. if not then ill look into timing? fuel pump? injectors?
Old May 11, 2004 | 06:42 PM
8200RPM's Avatar
local hippie
update:
i changed the rotor and still sputtering
check timing?
Old May 11, 2004 | 06:50 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8200RPM &raquo;</TD></TR><TR><TD CLASS="quote">check timing?</TD></TR></TABLE>
Old May 11, 2004 | 08:01 PM
boostn420's Avatar
Default Re: ignition related? (CivicRyda2k)
There is a ground from the wire harness on your thermostat housing. Check that, make sure its tight and has a good connection. When its loose you get sysmptoms very similar to yours.
Jorsher
Jul 21, 2006 09:55 AM
CleanLikeJdm
May 23, 2005 08:03 AM
8200RPM
May 2, 2004 10:09 AM
Jon5240
Oct 25, 2003 08:35 PM
XEF-9X
Oct 5, 2002 07:57 PM
