How much "play" do the stock motor mounts have?
Old May 4, 2004 | 10:24 AM
RTW DC2R's Avatar
Default How much "play" do the stock motor mounts have?
Should you be able to stand there and shake the motor with your bare hands? I think my car is due for some mounts, but Im not sure how much play is normal. I hate the sloppy feel it gives throttle response but Im not sure if I wanna go with some poly mounts or just some new stock mounts.
Old May 4, 2004 | 10:30 AM
1GreyTeg's Avatar
Default Re: How much "play" do the stock motor mounts have? (RTW DC2)
You want some serious motor mounts? Go check out Daves R next time he has it out. The motor does NOT MOVE! The whole car shakes and rattles but the motor is stiff as Fawk.
Old May 4, 2004 | 10:33 AM
RTW DC2R's Avatar
well I saw Robs mounts recently, you can shake it by blowing on it lol. mine isnt nearly that bad, but you can move it around pretty easily. Not sure if I want mounts that are gonna be as stiff as Daves, my car vibrates and makes enough noises as it is.
Old May 4, 2004 | 10:38 AM
1GreyTeg's Avatar
Default Re: (RTW DC2)
I'm gonna play with my R tomorrow, I'll poke and prod a bit to see just how much it moves and let you know.
Rodney has the Mugen mounts and again it is very stiff but for some reason doesn't seem as teeth chattering as Daves.
It's a toss up for new ones, as always, comfort or performance and that fine line to balance on.
Old May 4, 2004 | 10:40 AM
RTW DC2R's Avatar
Sounds good, let me know what you come up with. My car is pretty raw powerwise, so I try to keep the rest as street friendly as possible since I do enjoy the occassional Sunday drive.
Old May 4, 2004 | 11:27 AM
Dan GSR's Avatar
yes, poly mounts kick ***
my setup
rear= prothane
front torque mounts= energy suspension
transmission upper=prothane
engine upper = stock, maybe change to prothane later on
and yes dave's motor does not move
my ideal setup would be all three prothanes, plus the jim fab torque mounts
Old May 4, 2004 | 11:45 AM
Jon D's Avatar
Motor mounts are for pussies.....get some high industrial strength twistie-ties . Actually...i recently busted a bolt that went throught the rear mount and after replacing it there wasnt what i would call play at all. Check and see if perhaps you havent also snapped a bolt that just hasnt fallen out as mine did. If one falls out you will know immediately....i could feel it in the linkage as well as vibrations.
Old May 4, 2004 | 12:29 PM
PM-Performance's Avatar
Default Re: How much "play" do the stock motor mounts have? (B18C-Rsi)
the stock ones shouldnt bee too loose. , but you can rock the engine a little. i installed all my inserts and will never go back . my **** dont move at all . its beastly. i love the feel. you get used to the vibrations after a while. i dont even notice it anymore. it only really shakes at idle, just vibrates the mirrors a little, chics dig em too. makes em nice and wet.
Old May 4, 2004 | 12:57 PM
RTW DC2R's Avatar
Default Re: How much "play" do the stock motor mounts have? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">chics dig em too. makes em nice and wet. </TD></TR></TABLE>
like you would know anything about that haha
Ill probably rock the polys
Old May 4, 2004 | 03:12 PM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">the stock ones shouldnt bee too loose. , but you can rock the engine a little. i installed all my inserts and will never go back . my **** dont move at all . its beastly. i love the feel. you get used to the vibrations after a while. i dont even notice it anymore. it only really shakes at idle, just vibrates the mirrors a little, chics dig em too. makes em nice and wet. </TD></TR></TABLE>
I have the same exact setup:
prothane uppers (race) and rear + lower ES.....
Old May 4, 2004 | 03:22 PM
Bbasso's Avatar
Hey leave my POS out of it
Yeah when I get some $$$ flowing again I'll be putting in the best that money can buy!
dafreeeze
19
May 14, 2013 04:33 PM
ej1gsr!
Dec 14, 2011 09:24 PM
hondaapi
Oct 20, 2008 01:52 AM
Bbasso
Mar 4, 2005 05:48 PM
Ross
Jul 18, 2004 10:21 AM
