2-Layer Headgasket for LS? Can I modify the OEM gasket?
Old May 4, 2004 | 10:20 AM
2chron4u's Avatar
Default 2-Layer Headgasket for LS? Can I modify the OEM gasket?
I'm installing some 404's and need to bump up the compression about .4 to maintain stock cranking pressure.
I'm thinking a 2layer headgasket would be best, I don't want to mill the head, because eventually i'll be installing some p30 pistons and my CR will be 11:0 which is already high enough.
Is it ok to just take the middle layer out of the OEM headgasket and use that? Or would a better idea be too buy the Mugen b-series gasket and use a dremel to fit it.
thx
Old May 4, 2004 | 10:41 AM
frenchy's Avatar
Default Re: 2-Layer Headgasket for LS? Can I modify the OEM gasket? (2chron4u)
you might get some better info in all motor tech, but i doubt you can just mod the oem gasket
Old May 16, 2004 | 02:03 PM
StyleTEG's Avatar
Default Re: 2-Layer Headgasket for LS? Can I modify the OEM gasket? (frenchy)
Yes you can modify the OEM gasket.
Just carefully drill out the rivits holding it together, and pull out the middle section.
Old May 16, 2004 | 08:10 PM
frenchy's Avatar
Default Re: 2-Layer Headgasket for LS? Can I modify the OEM gasket? (StyleTEG)
- sorry for the misinformation
chasmataz
Jul 25, 2010 08:35 AM
EK_EG_DC
Feb 25, 2009 08:39 PM
Toy Civic
Jan 24, 2007 02:04 PM
pinota
May 28, 2002 09:30 PM
