MAP sensor wiring help!!!
When I had my car boosted I was using a AEM 3.5bar map sensor and the wires had to be cut and a pig tail soldered on. The shop that did this threw my old map sensor plug away so I was lucky to find someone who had one on here from a JDM harness they had. The issue at hand is the wires are different colors, with the exception of one of the three which is the green with white stripe. My question is this.........in order from left to right when the MAP plug is installed on the sensor what is the order of colors on the wiring? This is from a 00 Si as well. Thanks!
dutchman5
Jun 1, 2003 11:55 PM
