HELP!! what AN fitting is this??
i just talked with stan..and got everything situated..
thanks everyone for your help.
Modified by EGkwazhimoto at 10:52 AM 5/5/2004
Modified by EGkwazhimoto at 11:02 AM 5/5/2004
there is no way anyone could tell you what size that is, they could only suggest to you what it could be. Go to your local parts store and match it up. If you don't have one close, then if you think the side in the rail is -06, then the other could be -04. You have to do the leg work here!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">looks like -8 to -6 adapter if thats an aem fuel rail.
greg</TD></TR></TABLE>
Agreed.. I tried an an6 adapter on my fuel rail and it didnt fit quite right.. I had to get another fitting to go into the aem rail.. If you need the fitting number let me know and ill look it up, I know its meant to go on to a carburator but fits the aem rail perfectly..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGkwazhimoto »</TD></TR><TR><TD CLASS="quote">its an aebs fuel rail...(is it the same as the aem one?)
and tgreaves..let me get the part number if u can....thanks.</TD></TR></TABLE>
Mine was Earls part 840106.. Its a 9/16 x 18 threads..
This should help out more.. This is from when I asked the same question..
https://honda-tech.com/zerothread?id=649176
TRUST8383
Dec 4, 2003 06:26 AM
