Emissions help!!
Old May 3, 2004 | 10:32 PM
angst1313's Avatar
Default Emissions help!!
I have a 92 Civic EX 1.6 VTEC, and it tested barely over the limit for carbon monoxide, yet enough to fail. I have been given different advice from different local shops. One advised me that I should replace the plugs and plug wires. Another advised me that it I would need to replace the oxygen sensor. Another told me that I may need a new throttle body. So basically, every answer under the sun. Any knowledgeable, unbiased folk out there with some great advice (who are not just looking to sell an expensive uneeded repair job)? Thanks in advance!!
Old May 3, 2004 | 10:40 PM
greddydelsol's Avatar
Default Re: Emissions help!! (angst1313)
Dunno what u have available to u down there, but here I'd say 94 octane + methyl hydrate?
Old May 3, 2004 | 11:27 PM
superchin's Avatar
i dont know how emmisions work for you but i always thought obd1 cars only get checked for codes while being run for bout 5-10 mins. in IL only OBD2 cars get the exhaust hooked up to check for carbon monoxide so i cant help you there, all i had to do is reset the cel before i brough it into the test center.
Old May 3, 2004 | 11:33 PM
poison's Avatar
How old is your cat converter?
Old May 4, 2004 | 09:20 PM
angst1313's Avatar
Default Re: (superchin)
In AZ, the DEQ requires all cars 91 and newer to do exhaust testing as well.
Old May 4, 2004 | 09:23 PM
angst1313's Avatar
Default Re: Emissions help!! (poison)
As far as my cat, I'd imagine that it's 10 years old since my Civic is a '94. I've only had the car for about a year. I just changed the plugs, air filter and more than likely, will be replacing the Oxygen Sensor this weekend. I'll try the test again and see how it goes. A case of trial and error I suppose.
Old May 4, 2004 | 09:27 PM
angst1313's Avatar
Hey Superchin, how do I reset the cel? Sorry, I'm kind of a newbie when it comes to Hondas. I used to drive an RX-7. This is my first Civic.
Old May 4, 2004 | 10:39 PM
b-powa's Avatar
Default Re: (angst1313)
if it is a little over like 100 a new cat will pass it for sure.. my gf car dropped 1300 on nox by changing the cat and 300 on carbon.. if it is 50 or so just add seafoam for 5 bucks.
acmeotally
37
Jul 15, 2015 02:47 PM
PHAT-INTEGRA
Northwest
Sep 30, 2013 03:22 PM
killakalipoph
Feb 1, 2010 04:48 AM
obd1_crx
11
Aug 5, 2008 01:37 PM
2000CX
10
Dec 15, 2003 06:59 AM
