Cold start problem...Help please...
Old May 3, 2004 | 10:20 PM
busta's Avatar
Default Cold start problem...Help please...
A friend of mine has just swapped a d15b7 into a 92 vx hatch...after the car sit over night it takes about five cranks to get the car started and once it's started when you try to give it some gas the rpms drop...when you let go of the gas it goes back up...then when the car get a chance to warm up for 5-6 min everything is fine again...anyone got any input?
Old May 3, 2004 | 11:29 PM
superchin's Avatar
does it make any wierd sounds? like your oil is slushy?
Old May 3, 2004 | 11:34 PM
poison's Avatar
Default Re: Cold start problem...Help please... (lilobusta)
Try cleaning the IACV with brake or carb cleaner.
Old May 4, 2004 | 08:38 PM
busta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Try cleaning the IACV with brake or carb cleaner.</TD></TR></TABLE>
We actually had two different motors in...the vx motor din't have the cold start problem...after the first swap we experienced it...we thought the motor was bad so they actually sent us another motor too...we put the new one in and still have the same problems...'m thinking it something with the wirings but we used a ex wiring harness too...and still the same o thing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superchin &raquo;</TD></TR><TR><TD CLASS="quote">does it make any wierd sounds? like your oil is slushy?</TD></TR></TABLE>
not quite sure what you mean...(slushy oil?)
Old May 4, 2004 | 08:44 PM
BatuKing's Avatar
hmm timing ?
Old May 5, 2004 | 08:42 AM
busta's Avatar
anyone else?
Old May 5, 2004 | 08:43 AM
busta's Avatar
The CEL is on too...just tried jumping that and no codes where thrown...
myprelude
Mar 27, 2006 06:41 PM
WhiteVX
Nov 17, 2005 05:13 PM
dirtySOHC's
Mar 5, 2002 10:31 PM
Petah
Aug 19, 2001 09:31 AM
